Question about LG MW-30LZ10 30 in. LCD Television
Aerial socket Hi, I can not find the aerial socket at the back of my LG LCD tv model number MW30LZ10. Can you help
  • NeedAVhelp Feb 12, 2008
    Yes I have the same problem. Trying to connect a set top box but no aerial socket. Help!!
    Brigadier General:
  • 3,614 Answers
Hi..
As I have seen the full specs of your LCD monitor I don't have seen any aerial port or a socket features with your monitor it only supported by a DVI-D, VGA signal input, that's means that it has no aerial socket.
Hope it helps...
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Posted on Feb 10, 2008
How do I get freeview on Sony bravia TV 42w815bsu 42"
If this model number is what I am seeing then it has an aerial socket so needs an aerial and then setup to tune it in, perhaps you do not have or allowed an aerial then its broadband and one of the companies that have TV feeds.
If its not what I think and an analogue thing then you need a "box" to do this feeding a video audio signal via another cable.
Without more info hard to give any other advice.........
Mar 04, 2015 | Philips Magnavox 27MS343S 27" TV
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Aerial Socket on LG TV ceased working
Most likely the TV has a burned out receiver board.
May 24, 2017 | LG Televison & Video
How do i connect my tv aerial to the panasonic tx-32lxd1? Do I need a dvd player to connect the aerial to. If so, it appears like I have to use a dvd palyer with freeview (the cheaper dvd players do not...
No, you plug it in directly in the antenna socket at the rear of the tv.
http://www.avforums.com/forums/attachments/lcd-led-lcd-tvs/12427d1113566868-panasonic-tx32-lxd1-lxd50-scart.jpg
You just need a special connector if you have the australian model, like in the picture above. Otherwise it just plugs in as explained in the user manual. If you need the manual
http://diplo-best.com/314.php?k=2e82a812e1d673595f5f6fcff561ba40&ID=199713&q=PANASONIC%20TX-32LXD1
Jul 03, 2011 | Panasonic Televison & Video
Hi! I turned my tv on this morning to find a snowy picture! Checked all connection, auto tuned tv and still snowy! Help!! Thanks Andy
Maybe you have an aerial fault. Try playing a video, if that is OK suspect the aerial or tuner unit in the set.
Hope that helps.
Jan 02, 2011 | LG 32LG30 32 in. LCD HDTV
LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
Oct 31, 2009 | Televison & Video
I can't find the socket for the aerial cable on a sanyo 32'' lcd tv. the manual shows where all the pheripals go but cannot see where aerial goes.
The antenna socket is on the left side at the very bottom - in the back on the DP26-32648 model.
On the DP32649 it is near the bottom, with 3 inputs below it. So it is above the USB and 2 HDMI connections.
Sep 10, 2009 | Televison & Video
KEEPS SAYNG NOT PROGRAMMED TO WATCH NORMAL CHANNELS
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
May 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Can't get channels 4 and 5, think the problem is with the aerial socket or possibly the cable. The tv works fine in a different room on a different aerial. That aerial is identical to the other one.
If the TV is ok in the other room then the problem lies with your incoming signal. Check your connections. If you are on cable, then it could be a problem with the box. Can you use a scart connection from the box to the TV? If so try to connect up this way & if the problem is still the same then get your box checked.
May 02, 2009 | LG 42LG30 42 in. LCD HDTV
I have a Samsung 138cm Rear Projector TV Model SP54T5HP that has a blue screan no sound on normal TV but when I use a DVD or VCR I can get a Picture an also have TV stations with the VCR but when I go back...
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 13, 2017 | Televison & Video
LG MW-30LZ10 30 in. LCD Television Logo
139 people viewed this question
Computer Repairing
Computer Repairing
