Back to:
Tags:
Receivers
Generic problem for all Receivers
Cd player fault quick fix any one?
posted by timbo2007 on Feb 10, 2008
inserted cd into the player and the display flashes up f76 and then powers off !panasonic SC-PM65MD
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 10, 2008
FixYa! (100)
robotek
Rank:Guru Guru
Rating: 90%, 562 votes
You can do a few things to see what may happen.
  1. Check the spindle height. The platters sometimes slip down the shaft, or the spindle motor bearing drops and the platter gets closer to the lens.
  2. check that the spindle motor has not become lazy and "poling". give it a few spins. then try to read a disc again.
  3. Clean the laser lens with a cotton wool bud moist with windex glass cleaner. Then "polish the lens with a dry one.
  4. the spindle motor top bearing is worn and the payer mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. More likely to happen at the start of a disc, because the disc is spinning fastest whilst reading the TOC.
A drop of light machine oil from a syringe oiler can help the bearing to spin an not produce the knock. Only a short term fix to give the motor a "lube". Once the oil leaches out of the worn bearing the problem will return. I have run motors immersed in an oil bath to rejuvenate them before... but better to replace it anyway if its suss at all. Good luck, You could bump my profile by giving me a "FixYa" rating for my sharing my "knowhow". Any problems check back with me here.
regards
Graeme.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on cd player fault quick fix any one?:
I don't want to Accept this solution
Can you Help with these Receivers problems?
Receivers
We have a 2004 Cadillac SRX and the CD player is stuck. ...
Receivers
hi i have a alba stb8 free view box i turned it on last...
Receivers
Teac AG - D9260. No display. Not functioning but main...
Receivers
the eleca amp stoped having power
Receivers
feedback
Loading problems.
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
