Question about Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8143 help please! F11 coming up on display..
Hi.
Was just wondering if anyone knoew why my washing machine, stated above, keeps having the digits F11 come up on the display.
This has happened twice now, once a while ago and has reoccured now.
Any help would be gretefully appreciated.
S.
  • 2 more comments
  • stacey86 Feb 25, 2008
    Thanks for your advice.
  • jo-o Mar 01, 2008
    do i need a new washer or can it be repaired i too have f11 flashing
  • blake_lorna Mar 11, 2008
    18 months old and I have this on my machine too, what can I do?
  • Ivanhoe 1938 Apr 03, 2008
    Have the same problem. F11 comes up on display and machine will not start. How do I fix this please ?
    Ivanhoe1938
Ther's a water level contol system on these. a plastic 'water holder' is a push fit into the outer drum (at the front,& difficult to get to - undo screws underneath and open the front like a door, without putting too much strain on the door seal) a flexible black pipe or tube is connected onto this water holder and goes up to a electronic control with adjustment screws on the r/h side ,front top. FIrst check the water holder isn't blocked with old washing powder by pulling straight out of the outer tub (its a push fit)& blowing through it..
Second do the same with the black tube.
Third make half turn adjustments to the electronic water level sensor - just pull it away from it's snap fit mounting and you'll see 3 adjusting screws -your choice but usually the lower one.-hey presto
Posted on Apr 24, 2008
It's a communication error between the ccu and the mcu (motor ctl unit). i've seen lots of problems with the mcu.
Posted on Feb 12, 2008
The machine displays FH, what does this mean?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Jul 02, 2010 | Whirlpool AWM8143 Front Load Washer
Hi I have a AWM8143. then i start a program, the machine, takes the water in, but the drum does not move, its trying to rotate but it can't. After 30 seconnds, the machine is stopping and the display...
The machine belt will be very tighten position so that is unable to rotate else bearing may be defective kindly replace the 2 inner bearings along with washer
Dec 24, 2009 | Whirlpool AWM8143 Front Load Washer
Hi I have a Whirlpool 6th Sense Washing Machine - AWM8143. I is washing and spinning perfectly well and there are no error codes. However when it spins the machine makes a grating squeaking noise that is...
hi,
looks like there is some friction between the main and outer tub of your machine. there is generally a mechanism for smooth spinning of the machine in good rpms for wash-spin cycle. this could be because of rust formation, or mud collection. please refer your manual and remove the 3 screws behind the lower front plastic cover, and look for rust formation. scrape the rust and try spinning again.
cheers
Jul 26, 2009 | Washing Machines
FAULT CODE F11
F-11 like a Kenmore means communication error between the motor control and the main control. Check connections, unplug and replug computer connections and see if problem persists. I've seen cases where either board or even both can be bad.
Feb 08, 2009 | Whirlpool AWM8143 Front Load Washer
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Fault code F11 on whirlpool AWM8143 6th sense mwashing machine
got this from another site....
Starting to see these fault codes pop up in these otherwise fine machines. The F/11 code is just a generic code generated when there’s a communications error between the two main control boards in the washer. These two boards are the motor control unit(MCU) and the central control unit(CCU).
A common problem is the wiring harness jiggling loose; remove and reseat it and that usually fixes it. If not, then you’re looking at spending some money on control boards. Yes, I said boards, plural. The really sucky part is that there’s no way to definitively and conclusively prove which board, the MCU or the CCU, is at fault so, unfortunately, that only leaves the parts changing monkey method: replace both boards,
But, on a brighter note, the electronics are covered under warranty for 24 months. If your machine is older that this, then you’ll need to shell out some shekels
tnx 4 using fixya,
drcool
Oct 05, 2008 | Whirlpool AWM8143 Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
AWM8143
FA is the emergency shutoff switch that detects when water is pooling underneath the machine -> a leak.
"Check float switch under machine, empty any water from catchment tray, check for water leaks or oversudsing".
Jul 10, 2008 | Whirlpool AWM8143 Front Load Washer
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
