Question about Panasonic NV-HD680 VCR
Setting the clock/time
Steps to take to reset time on clock display
Steps I should take to reset time on clock display Hitachi FX 6500
Posted on Mar 11, 2008
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
May 02, 2011 | Samsung B5722 Cell Phone
HOW DO YOU SET THE CLOCK ON THE DEP-P4000UB
STEP ONE (PRELIMINARY): With the key in the ignition, turn the ignition to ACC (accessory power) or this can be done while the vehicle is running. If unit remains off, proceed to the next step, but if unit is already powered on, power it down by pressing [Source] until it goes off. (Then, proceed to the next step.)
STEP TWO: Press MULT-CONTROL & hold until CLOCK SET displays. (To cancel at any time, press [Band/ESC]. Press [Back] to return to previous display.)
STEP THREE: Press MULTI-CONTROL to select the desired segment of the clock display to set. Each time MULTI-CONTROL is pressed, it selects (blinks) one clock display segment: Hour - Minute.
STEP FOUR: Turn (or push) MULTI-CONTROL (up/down) to change the clock display segment setting.
Apr 10, 2011 | Pioneer Car Audio & Video
I have programmed the GE HEAVY DUTY TIMER MODEL 15117 timer to come on at 7 pm and it does not turn on the outdoor lights. the dots between the hour and minute are flashing. What am I doing wrong. It is...
There are 6 programming buttons on face of 15117 timer.
Download pdf manual
Review of steps:
The AA battery is installed with correct polarity
Timer blinked 12:00
Set clock while holding down clock button
Press PROG to display EVENT1-on (there is a tiny 'on' that shows on display)
>day button selects day, weekday, weekend
>> hour minute buttons to set ON time for EVENT1
>Press PROG so display shows EVENT1-off (ther is a tiny off that shows on display)
>repeat steps above to set OFF time for EVENT1
>Press PROG until EVENT1-on shows in display
>repeat steps to set on-off times for EVENT2
> when finished programming, press CLOCK
> Last step, set mode
MODE is on-off override
MODE is also Automatic or Random
Solution ideas:
Press MODE until Automatic displays)
-Press MODE key to see if manual override works
-Look at digital face (or take photo of it) and compare with Figs shown in manual to see if there is a match
-Check breaker. Check light bulb. Remove timer and see if load works without it. Check that light switch is turned on if plug is controlled by light switch.
-Review programs: Push PROG key to review programs
-Other timers ignore conflicting schedules ... for example EVENT1 says ON at 7 and OFF at 8, but EVENT2 says opposite, or overlaps, then timer ignores programming
-Reset timer and repeat programming: Press CLOCK, MODE PROG to reset timer
-Make a chart of your EVENT1 on-off times, and EVENT2 on-off times, EVENT3-7 on-off times before programming to make sure there are no conflicts.
Oct 04, 2010 | Heavy Duty Hardware & Accessories
Need to know how to change time on Comdial GCA70-281
  1. Programming the time and date for a Comdial Impact digital phone system must be done from the attendant's station, usually the phone located closest to the Comdial controller. Go to this station before attempting to change the time.
  2. Step 2 set-clock_thumb.jpg Now the phone system's clock is ready to be reset. Without picking up the handset, press the "Intercom" button on the phone. Dial * # 0 1. The digital display2.gif should read "Set Clock"
  3. Step 3 Set the year by dialing two digits (00-99)
  4. Step 4 Set the month by dialing two digits (01-12)
  5. Step 5 Set the day by dialing two digits (01-31)
  6. Step 6 Set the hour by dialing two digits (01-23)
  7. Step 7 Set the minutes by dialing two digits (00-59)
  8. Step 8 set-clock2_thumb.jpg Comdial Impact phone with updated day and time. Pick up the handset and set it back down to set the programming changes. The new date and time should display immediately on all phones connected to the Comdial system
Nov 04, 2009 | Comdial Impact 8124S Corded Phone
How to set time with new control board?
You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
Panasonic dmr-eh50 Clock setting greyed out - unable to reset clock after clocks went back.
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Oct 26, 2008 | Televison & Video
HOW DO YOU SET THE TIME
The time on the phone system has been reset, but you must refresh your system.
1. Press menu button
2. Press the time/day button, which displays current time & day--wait for it to time out (in other words, the screen clears and returns to menu).
3. Press exit.
Repeat steps 2 & 3 to display your clock and check time.
THIS REFRESHES YOUR CLOCK TO THE ACCURATE, CELL-TOWER TIME.
Jan 16, 2008 | Lucent Definity 8403 Corded Phone
Panasonic NV-HD680 VCR Logo
156 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
