Question about Elektra (SX) Espresso Machine & Coffee Maker
Saeco via venezia overheat cut out
Have had my saeco via venezia in for repairs 3 x now because it overheats and trips its overheat cutout switch. Would love to know how to reset it myself as it takes 4-6 weeks to get it through the repair centre. It happens if I steam milk and forget to run water back through the boiler. Any soultions?
  • 2 more comments
  • gripmoto Feb 13, 2008
    Thanks - I know that. How do you reset it though, that is the issue!
  • murphmaster Mar 02, 2008
    Our steamer on the barista athena stopped foaming recently. It seems to be more explosive towards the end. Could there be some saftey switches that went on for not having water in the tank and running it accidentally? Is it something that we can take care of without sending it in? We love it otherwise...
  • Bart42 Mar 26, 2008
    Take out the 5 or 6 grub screws securing the main steel cover and remove. You will see plastic re-set switch on top of the boiler amongst all the electical connections - just click it.
    To stop it cutting out be sure to fill the boiler immediately you swith the machine on by opening the steam valve until water comes through the nozzle. Also remember to switch off the power as soon as you have brewed - that's my usual crime!
    Regards,
    Russell
  • Mila17
    Mila17 Sep 05, 2017
    Hi Bart42 - I had the same issue. I saw a photo that someone posted of the re-set switch location. It looks like there were 5-6 areas with wires coming out. I looked and mine and I only have 4 terminals, and no re-set switch. Any other ideas on how to re-set the machine?
Disconnect from the power and remove the 5 or 6 grub screws retaining the main steel cover and take the cover off. You will see a plastic re-set button on top of the boiler amongst the electrical terminals - just click it on again.
To stop overheating always open the steam valve immediately you switch the machine on until water squirts out - this tells you the boiler is full & not dry! Also remember (unlike me!) to switch the machine off as soon as you have finished brewing...
Bart42
Posted on Mar 26, 2008
    Problem Solver:
  • 4 Answers
We had trouble finding the plastic reset switch but found it between where the 2 blue wires attach to the boiler. The switch looked the same colour as the boiler so it was a little disguised as being a switch. Thanks for the great tips. You saved us a fortune again let alone the time we would have had without our coffee machine. Cheers
Posted on May 08, 2009
  • Mila17
    Mila17 Sep 05, 2017
    Do you have a photo of what this looks like? I cannot find it on mine. I love this little machine, but its hard to justify finding someone to fix it again (parts and labor will be well over $100 again). Would love to be able to save it myself if possible.
I'm sorry to be the bearer of bad news, but you need to run water back though the boiler--all that's there when you're steaming is steam and without water all the safety switches go on.
Posted on Feb 13, 2008
  • 80 Answers
Check reset button if you have the same problem again change both termostat on tank
Posted on Jul 11, 2009
2 Suggested Answers
SOURCE: overheat cutout switch
The coffe maker has a heat fuse attached to the side of the pump so when over heats that melts and does not damage the coffee maker
They charge $100 to replace which is a bit tough, you could bypass easily but could damage the machine if not careful
as we have two and one has just stopped pumping, not picking up water so maybe worn valves and I just have it all to bits and noted the heat fuse on the side of the pump
Posted on Mar 13, 2008
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
www.youtube.com/watch?v=8L8vdfMOx2g
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
We have broken the handle on pressurized portafilter for Saeco Via Venezia espresso machine. where can we get replacement?
I don't think the handle is sold separately. Seattlecoffeegear does sells both a bottomless and an unpressurised portafilter for the Via Venezia. Both would be considered upgraded gear vs the pressurized one.
Jan 30, 2013 | Saeco VIA Venezia
Saeco VIA Venezia i have just tried to steam milk but i think i may have overheated the steamer. Machine will not work at all now. is it dead or can it be repaired.
I checked on your site for any similar fault and came up with a response from Guru. Just had take the casing off and reset the the machine and now it works perfectly.
Many thanks
Jan 24, 2010 | Saeco VIA Venezia
Saeco classico is overheating
Yes. Check the thermostats on the boiler.
Apr 17, 2009 | Saeco VIA Venezia
I can't find user manual for Saeco Via Venezia. I
Do not use vinegar, but any non toxic commercial descaler can be used, as long as you remember it is a small machine use less.
Mar 08, 2009 | Saeco VIA Venezia
I need a new black steam wand for a via venezia. Where?
Your best bet would be Saeco.
Their contact information is:
Saeco USA Inc.
7905 Cochran Road
Suite 100
Glenwillow, OH 44139
800-933-7876 (toll-free)
440-528-2000 (phone)
440-542-9173 (fax)
Feb 22, 2009 | Saeco VIA Venezia
Have a Saeco Via Venezia I think it overheated and tripped its overheat switch, as it the light no longer comes on. I have taken the cover off however cannot find the switch, can you help me
I believe you have a digital system, there is a thermal control setting in the system that may have been improperly set at the factory. We sent a new system back with the same problem and they made the fix.
Best Wishes,
Lane
Jan 18, 2009 | Coffee Makers & Espresso Machines
Saeco Via Venezia Cappacino Machine The black plastic sleave for the frothing arm has melted and no longer fits on - where can i get a new one? I am based in Canberra - its a Via Venizia Espresso
Contact Saeco Australia to see if they can help you.
Saeco Australia Pty Ltd
6/87 Newlands Road Reservoir
Victoria 3073
Australia
Tel.: +61 3 94624949
Fax: +61 3 94624955
E-mail: info@saeco.com.au
/Mirran
Aug 31, 2008 | Saeco VIA Venezia
Via venezia Expresso
Perhaps you dont need to change a fuse. but only reset them :)
open up the machine and look for the boiler. on it are two automatic fuses that you can reset.
Hopefully its that otherwise it might be the powerboard.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Overheat cutout switch
Feb 10, 2008 | Saeco VIA Venezia
Elektra (SX) Espresso Machine & Coffee Maker Logo
1,667 people viewed this question
Top Elektra Coffee Makers & Espresso Machines Experts
Jaime Hernandez
vilhj
Level 1 Expert
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Elektra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
