Dualit Espresso 889 Espresso & Coffee Maker
Problem for Dualit Espresso 889 Espresso & Coffee Maker
The frothing stick doesn't seem to work
By maidment on Feb 10, 2008
The machine is now about five years old and has beens sent off to replace the seal once already. The new problem is that the frothing stick no longer seems to produce enough steam to make the milk frothy, also it no longer stops when you switch it off, just carries on hissing for a boy twenty seconds.
Any suggestiions?
Solution #1
posted on Jun 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi,had same problem.Caused by end of frother becoming clogged with dried milk.Unscrew end of frother from plastic ring and try to remove blockage with a thick needle or something.Probably a good idea to descale machine at smae time.If you remove the end and then try steaming it should show that the blockage is right at the end.
Solution #2
posted on Feb 10, 2008
Not Rated)
pierre235
Rank: Guru
Rating: 87%, 826 votes
descaling time not with vinegar with descaler vinegar remove calcium in little piece descaler melt it use 1 part descaler 1 part water put in the water container start it up open valve after a few second turn it off leave it for15 minute repeat untill empty after do 2or3 rince descaler is corosif thank you for using fixya pierre
Was this helpful?
Yes
No
Popular Solutions for Dualit Espresso 889 Espresso &
Questions and Unsolved Problems for Dualit Espresso 889 Espresso &
Do you recommend Dualit Espresso 889 Espresso & Coffee Maker?
Answer
Answer
when we switch to steem to froth the milk it is not supllying steem
Answer
Identical to the above. Any answers?
Answer
I have a Dualit coffee machine model 889 that is about 6 years old. No steam is coming out of the... (More)
Answer
Please help, my machine steamer seemed 'blocked' but otherwise worked fine. I descaled it and ever... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
