Servis washer/dryer my new servis washer/dryer is leaking water from the front l/h/s. the hoses are okay, please help
  • Andy Tarrant Feb 11, 2008
    leaks all the time as soon as any water goes into the machine.
  • Andy Tarrant Feb 12, 2008
    It is brand new so we have contacted the supplier and they are coming out tomorrow. Thanks very much.
    Scholar:
  • 90 Answers
Leaking all the time or just when it is in certain cycles?
Posted on Feb 10, 2008
  • Timothy Smith Feb 12, 2008
    I would suggest getting it looked at by a tech as it may have a crack in the tank which should be a warranty issue. The only way to figure this out is to have the cover off and look at it as the water starts coming in. Is it possible to take an access plate off allowing you to see inside? Anyway if it is new contact the distributor and see if you can't just exchange it.
I have a Servis M9409S washer dryer. The dryer isn't heating up at all, and I'm assuming it's the heating element. Does anyone know how to replace it?
There is only one place that I can find that part: http://www.partmaster.co.uk/servis/m9409/element/catalogue.pl?path=66991,61187:66997&model_ref=29129&refine=element
Jun 05, 2014 | Dryers
Servis 1100 rpm manual needed Moved in into a new house with a Servis 1100 rpm washing machine but there is no manual; As the company Servis does not exist anymore - where can I get a manual...
You will need to type into your search engine/web browser '(make) washer manual' and you might be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
(I have just typed in 'servis 1100 manual' and there are a number of sites from which to select))
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 18, 2011 | Washing Machines
I need new thermostat for servis tumble dryer m2007blk cant find anyone that stocks them servis gone to liquidation
try:
http://www.spares2go.co.uk/browse-M200-Tumble_Dryer-SERVIS-spares-m164-p5630.htm
Nov 25, 2010 | Dryers
Help please i have a servis m6000-1 overheating
Frst of all check that the incoming water supply is cold water to the washer, if you can verify it is, then it sounds like it is not rinsing, so I would suspect a blocked pump filter or pump.
You need to check that it is draining properly.
May 24, 2010 | Washing Machines
Washing machine problem
press the half-load button when you need dryer to work, make sure wash dial is at end position
Feb 03, 2010 | Servis Dishwashers
Washing machine pouring water out on final spin
The rubber pipe under the machine is usually parished......
Feb 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Servis m6160w logic 1600 tripping rcd
many servis have an induction motor but later models have a brush motor.
worn brushes will not cause an earth fault. suspect part of the motor windings are down to earth. also possible you have a leak in the tub or door gasket so that on spin, water is thrown onto an electrical item
Aug 10, 2008 | Washing Machines
Changing door gasket on Servis M9813s washer dryer
you can clean in situ just as good as if you remove it
Jul 12, 2008 | Washing Machines
Washing Machines Logo
194 people viewed this question
Top Washing Machines Experts
