Question about Konica Minolta magicolor 2400 Laser Printer
2400w Konica Minolta Magiccolor
Had the problem before and support had me download a driver (I think) Said they had found problems with the printer losing its connection. It gives me an error on the printer looks like a lightning bolt or a paper jam. it will not pick up the paper but attempts to. You can hear the stuff turning but it wont pull the paper in. I can manually turn shaft and get the paper to start - I think it is out of rotation and will not continue after I install the cartridge.
  • 6 more comments
  • Anonymous Feb 21, 2008
    Error
  • worthington Mar 24, 2008
    I just moved, and when I set my office back up. The printer keep getting jammed. It get to the top but I think the fuser stops turning before the end of the print job and the paper jams there every time.
  • Anonymous May 12, 2008
    paper feed does not pick up the paper and it reports error as a paper jam but there is no paper jam. I have to reopen the top door and restart. Continues to have this problem.
  • RobertMonroe May 13, 2008
    I changed the OPC Imaging Drum. Now my printer is sending a message which states that the specified path is invalid? I unistalled the printer and re-installed it and the same error message appears?
  • markstuff Sep 10, 2008
    The printer starts up and turns and turns and then shows an errror message.
  • laupost Dec 26, 2008
    Keep getting a paper jam error but no paper jam exists. I have performed every troubleshooting fix on the Konica Minolta site and still no luck. Don't know what the solution to this is except to replace printer ;(
  • Anonymous Mar 24, 2009
    Printer indicates there is a paper jam with the appropriate error code yet after thoroughly looking for paper in the path there is none.
  • Anonymous Apr 09, 2009
    Yep -- same issue for me. Sounds like it's going to print, but barely moves the sheet of paper and I get the media jam and the red lightning bolt error message. I've tried some of the "cleaners" -- sheets that you feed throught the machine to clean the paper path but (PathKleen) the brand I used seeme to not only NOT help but made the paper jam when it did partly feed through the 2430 DL. I'm disappointed in the performance of the printer, based on this issue.
My paper feed does not pick up the paper and it reports error as a paper jam but there is no paper jam. i continues to have this problem. i think it is a piece of junk.. i wish i never bought it
Posted on May 15, 2008
  • phpatel1 Dec 08, 2010
    I was having the same problem, after contacting "Konica Minilta" and ask for nearest service center. Diagnostic was free, issue was due to bad roller. Estimate to replace the roller including labor was about $150, since all toner cartridge was replace few week ago so decided to replace the roller, and is working fine.
    Champion:
  • 214 Answers
Dont understand your problem quite well, but, for a connection problem, update driver, change usb cable and last if nothing helps, update firmware.
for a paper take up problem,:
turn off printer,
remove cover,
remove drum cartridge,
under that there is take up roller, pull the knob and move the roller to right, then you can pull the take up roller out.
first try to clean it and also clean plate under the take up roller. if thats not helping, then you have to cut the biger (larger) plastic sides of the take up roller a little smaller..
should help.
good luck
Posted on Feb 11, 2008
KONICA MINOLTA 2400W PRINT BLANK PAGES
Verify the drive transmission mechanism to developing unit,the image transfer current terminal and the scanner drive transmission mechanism.
Feb 13, 2013 | Konica Minolta magicolor 2400 Laser...
I just install a konica minolta magicolor 2400w printer on a computer thats running vista. Everything seems to be installed correctly but when I go to print something, it would not print, the ready light...
I have a Konica user guide for your printer here:
2400w User guide PDF
Have a look at the introduction and troubleshoot sections for the light blink codes, these give you an idea if it could be an error.
May 14, 2010 | Konica Minolta magicolor 2400 Laser...
How can i install my printer magicolor 2400w with no cd
Thank you for your question.
I have provided a link to the page where you can download the driver for your printer. You can save it to your computer and when installing the printer, point the "wizard" to the file you have saved when it asks for the driver.
Kind regards
Apr 22, 2010 | Konica Minolta magicolor 2400 Laser...
Where can I purchase a replacement fuser for konica minolta magicolor 2400w
You could buy it from :-
http://cgi.ebay.com/Konica-Minolta-Magicolor-2400-2400W-2430DL-2450-Fuser_W0QQitemZ180400879568QQcmdZViewItemQQptZPrinter_Accessories?hash=item2a00baf7d0
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 05, 2010 | Konica Minolta magicolor 2400 Laser...
Install konica minolta magiccolor 2400w printer without software?
Hallo,
I have a Konica-Minolta Magiccolor 2400 W. It wasn't used very often roughly less than 150 pages in 2 or 3 years. So I do not believe that I reached the capacity of this device. Now it says the black tomer is empty and need to be replaced. If one have a look at it: it is without any free place at the roll. So there must be nough tomer in it.
Please is there anybody who can provide an idea how I can set the information of this toner to zero again?
Thanks for your kind assistance.
aussi-dingo
Oct 16, 2009 | Konica Minolta magicolor 2400 Laser...
Lost disk and need to download printer driver for 2400w magicolor to my laptop
You will find the drivers here
http://onyxftp.mykonicaminolta.com/download/Search.aspx?ht=
If this helps please vote
Jul 02, 2009 | Konica Minolta magicolor 2400 Laser...
Vista print drive for the konica minolta 2400w
If you are using the USB connection, got Control Panel, Device Manager and delete/uninstall the last listed USB Hub - and wait a moment for the system to re-recognize what's connected. If there is a page in the cache, it will automatically start to print.
Sep 12, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
I do not have my installation cd handy and I want to add my konica minolta magicolor 2400w printer to my laptop. where can I go to do that online?
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=magicolor%202400w
There is the link for the drivers you need. Hope this helps you out.
George
Jul 16, 2008 | Konica Minolta Office Equipment & Supplies
Konica Minolta magicolor 2400 Laser Printer Logo
1,518 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
