Question about EnGenius EOC-3220 (EOC3220)
Need to change the channel
Hi i need to put the channel on number 14 but i don't no how lpz any body can help me
  • 3 Answers
Wich router do you have? usually you can change this from the main menu in the router BTW the channel 14 is used in japan
Posted on Feb 12, 2008
Lpz some body help for this fault
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Jan 02, 2017 | Sony Televison & Video
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
I have old motorola talkabouts..and don't remember to change the channel. can you help? They are Yellow and have no screen on them...I can't find any model number on them. the date is Dec 1998 it...
Hold the push to talk(PTT) button while turning the unit on, it will talk to you. press PTT to change channel, push monitor to switch to codes, press PTT to change codes. When you have the correct settings press monitor and it will confirm settings.
Jun 13, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
Hi, we have no program listings with channel numbers in top screen also no info bar when you change channels... hope you can help, kev
Hi, are you getting a picture or tv show when you have it in cable or dish? some channels don't give info but most of them should.
May 20, 2011 | Televison & Video
For no body used my wireless modem ineed put the pass word .thank you
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 28, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Philips Flat TV locks up on one channel and won't change
hi i need help cause my philips47pfl7704dif7 when i turn on the tv it just turn blue and wont let me change sources or channels . Help me.
Jul 25, 2009 | Philips Televison & Video
Re: Sony Bravia remote problems
sounds like you need to "autoprogram" your channels. In the customer menu search for "settings" (looks like a toolbox) select that, arrow down to "channels" select that, you'll see option for "autoprogram" select that. Any channel it sees it will lock in and you shouldn't have to press numbers anymore.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 27, 2009 | Televison & Video
Sub channels and how to turn them on
Beg to differ with your friend. Those small numbers are not sub-channels but rather are Interference Eliminator Codes. The represent what code is being used by the radio to eliminate other incoming transmission not with the same code (number). There could be similar radios working on the same channel/frequency, but if they do not have the same code then neither one would hear each other. This does not make a channel "private", rather it limits what one can hear on that channel to another radio with an identical setting of the code. In some Motorola models, pressing the Menu button until the small numbers/code flashes would enable them to be changed. To change, press the+ or - keys. Pressing the MON key or setting the code to Zero would enable the radio to receive and sound off all incoming signals with or without the code.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Motorola Talkabout T5100 (14 Channels)...
Need help viewing all public television channels
Your TV is set for standard broadcast. You need to go to the set up menu and change from antenna/normal to cable mode. In standard broadcast mode you receive off the air programs 2-13 vhf and 14-83 uhf. In the cable you receive 2-13 and cable channels 14 -125 if the set is not too old. When cable channels first came out some sets would just cover 14- 36 or 14- 47 or 14-66 etc. The newer sets cover the now standard cable channels 14-125. Hope this helps you Stargazer
May 25, 2007 | Quasar SP-2725 27" TV
Dont seem to be able to install channells in
Auto installation should search for local tv stations, or add new channels, then it will search for new ones.
Feb 20, 2007 | Philips 14PV225 14 in. TV/VCR Combo
EnGenius EOC-3220 (EOC3220) Logo
118 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Bhagyanath N
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
