Question about Lexmark Z640 InkJet Printer
Printer installed printer but it says working offline got test page printed but nothing else will print printer is only 1 year old got new laptop windows vista basic what else can i do
  • dozydots Feb 13, 2008
    I havae got the printer has default but still says working offline
  • 84 Answers
Try to go to your control panel, click on printers and faxes if you see your printer in there, right click and set as default.
hope this helps.
Posted on Feb 10, 2008
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
New ASUS PRO50Z laptop with Vista , trying to install new drivers for Canon PIXMA ip4500 printer. Have installed new drivers from Canon website, plugged in printer to USB port and turned on printer....
have you downloaded the right software? for vista. also try to print something from your notepad or wordpad or a website page see if it will print.
Aug 15, 2008 | Computers & Internet
My Dell Inspiron 1545 has stopped printing
first check the printer cable
then try to uninstall the printer driver
restart the laptop
try to install the driver again
print the test page
Feb 06, 2013 | Dell Inspiron Computers & Internet
Windows says printer offline, but it is not offline. network settings confirmed. windows firewall turned off. scanner works perfectly over network, but printer is "offline"
The printer offline error mostly troubles windows 7/8/10 users, The printers loses connectivity even when it is connected and operating. The status message displays offline on the computer, and the printer does not print. An Offline status indicates that the computer has failed to communicate with the printer. In some network conditions, the printer might get offline unexpectedly.
Before going to the solution for this you must know when and why printer offline error takes place:
The error may appear when Windows 8 diagnoses that the printer is unavailable, but unfortunately, most times it fails to tell whether the printer is really offline or if it has connectivity problems or printing errors. Reasons why your printer appears to be offline, include problems with hardware, such as disconnected cables or malfunctioning equipment, and problems with software, such as corrupted or incompatible driver files.
These might occur when:
1. The connection between the computer and the printer is slow/unresponsive.
2. The printer has encountered an internal error
3. There are multiple unfinished print jobs in the queue.
There are some simple steps you can follow before going to any complicated way:
Your printer offline can be a problem with the driver software. This is a small piece of code that Windows and the printers use to "talk" to each other. If the driver software is outdated, corrupted or incompatible with the version of Windows that you have installed, you may need to update it.
Restart the printer and the computer or unplug its USB cable.
Do check that the printer's power cable is plugged into an electrical outlet. If the printer is connected to a power strip, make sure the strip itself is connected to the electricity supply and is turned on.
In case you are using a network printer both wired or wireless, You restart the router as it may cause due to network failure.
Different manufacturers come with their own diagnostics software which can inform the user about the problems coming up (Ex : HP's Print and Scan Doctor), Use it as it will be really useful.
PRINTER OFFLINE ERROR Solution 1 :
Type in Services in your windows searches and hit the enter key. Click on Services option from the set of search results as shown below.
A new window for Services opens up. Scroll down and find the entry named Print Spooler.
Now right-click on Print Spooler entry and then on Properties option.
Set Startup type as Automatic from the drop-down menu.
As next, hit the Start button and wait till windows start the Print Spooler. Once done, hit Apply button.
Now if you look at the status of the Print Spooler, you can see that it is Started.
Solution 2 :
If the above method doesn't work for you, you can always try our second method. For that, type in Devices to the windows search and choose Devices and Printers from the search results.
Now find the printer that is offline and right click on it. Click on the option See what's printing from the context menu that appears.
A new window opens. Now click on the Printer tab and uncheck the option that says Use Printer Offline.
Aug 04, 2009 | Canon PIXMA MX850 Multifunction Printer
Printer wont print from computre.
try with test print
change the property of offline (untick)
check for any other printer installed on the computer
Apr 09, 2009 | Computers & Internet
Cant install lexmark x2600 on windows vista
You need to install the Vista version. Goto this site-download the driver-install-enjoy!! http://search.lexmark.com/printer/US/en/12L1685.html
Dec 17, 2008 | Lexmark X2500 All-In-One Printer
Hp psc 1210 not working in vista - but diagnostic utility shows all ok - and prints test page
Here is the full-write up on the HP PSC1210. Read through this thoroughly to ensure that you follow all the steps to make it work in Vista, since there is no Vista native driver.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp printer 5420 photosmart
sadone:
I assume all hardware connections are fine, and any lose cable connections are already checked then......
1)Send a test page to the printer Open up the print jobs, and try deleting all jobs (click on the printer from printer and faxes under control panel, delete all print jobs, Still in this window click printer and uncheck the print offline, does this help?) if not then
2)Try uninstalling and reinstalling the printer driver and then try printing a test page.
3)Try uninstalling and reinstalling the printer software and driver and then try printing a test page.
If nothing works then:
-Uninstall all printer software, driver unplug and reseat an original hp cartridge and go this link install software and driver and follow instructions on how to install the drivers, at the end click the check button to see if driver is fine. Now you should be able to print.
Dec 24, 2007 | Office Equipment & Supplies
Lexmark Z640 InkJet Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
