Thomson 32ws83kp I have lost all sound and screen shows on mute but i can't adjust any sound levels even with external amp.Also the poewer button flashes amber and green. does anyone have a service manual or no how to reset the unit. Cheers Antony
  • nagesh pai May 11, 2010
    sir,when you switch off your tv any light (in technical terms switch of raster) is there?
    Sergeant:
  • 395 Answers
Try unpluging the set for 5 minutes the replug in the set you should have function back. if the tv remote is a multi divice remote be sure to hit the TV button first.
Posted on Feb 11, 2008
The Akai TV MA TE02 lost sound
It sounds that the audio output section circuit has the fault. Check it audio out pre-amp sockets at its back, connected to any external Amp. See whether audio comes out by this way. If not, the main digital board is faulty. If yes, audio output section is faulty.
Dec 31, 2012 | Televison & Video
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
My microphone isent working on my laptop i plug a mic in and nuthen can be picked up
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Mar 22, 2011 | Thomson M140 Microphone
My microphone is built in to the computer but will not even show up in my recording devices. it used to work fine and now it doesnt say it even exists on the computer.
See last paragraph of instructions below re unlisted devices.
Click VOICE
That should be it.
Feb 19, 2011 | Compaq Audio Players & Recorders
My Mic is on all the time it is also coming through the speakers so when i turn external speakers on there is an huge feedback
See Adjust volume below
To use any microphone with your computer you will need to enable it in control panel. Instructions are for Windows XP but are similar for Vista and Win7
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and the volume slider is at the top of the scale.
Ensure the MUTE ALL box isn't checked before closing window.
Click VOLUME button in SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. The same applies to 'Internal MIC' if you are using a laptop with built in microphone - this must be enabled/ disabled separately to the external MIC.
To adjust audio volume.
You can also put a check mark in the box to show the volume control icon on the Task Bar so you can go straight to it to in future
Feb 10, 2011 | Toshiba (P000257700) Microphone
My 37" LG LF 77 television has poor sound. How do
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
Hello, thank you for sharing your problem with us, I would personally be happy to provide the most accurate and up to date information for you.
Here is a copy of your operators manual
http://us.lge.com/filedown.do?filepath=1000004174&fileName=PG60_manual.pdf
Solutions
Press the VOL (+ or -) button to adjust the volume. If you want to switch the sound off, press the MUTE button. You can cancel the Mute function by pressing the MUTE or VOL (+ or -) button.
2. USE THE SOUND MODE OPTION BUTTON
Sound Mode: Selects the factory preset sound for type of program.
3.
SOUND MODES
 Multi Audio: Changes the audio language (Digital signal). SAP: Selects MTS sound (Analog signal).
4. PAGE 88 thru 95 go extensively into details regarding sound adjustment
Jan 10, 2011 | LG Televison & Video
I lost my sound on my Samsung LN-T4061F tv. it was plugged into my stero.. was fine.. and now no sound. Not even on the regular tv. HOw do I get the sound to work at least on the regular tv?
hi,
i think ur tv's internal mute function is ON. change it to OFF through the following setup.
1. Press the MENU button to display the menu.
Press the ? or ? buttons to select "Sound", then press the ENTER button.
2. Press the ? or ? buttons to select "Internal Mute", then press the ENTER button.
3. Press the ? or ? buttons to select "OFF", then press the ENTER button.
Press the EXIT button to exit.
ok
Dec 14, 2010 | Samsung Televison & Video
I am attaching an external microphone and need to mute the internal mic. They both work and it echos. PLease help.
Adding a mike doesn't create echos/feedback. Windows? Version? Right click on speaker icon in lower right and go to recording device mixers, can mute and adjust level of sound sources, also microphone power and pre-amp. Telephones and other devices (laptops) with both input and output will feedback unless the input is "noise cancelling", so you will have to be much more careful with the placement of the external mike compared to using the built in mike.
Oct 14, 2009 | Computers & Internet
Lost sound on my GE (Thomson)46GW947X1
pls. first open your tv menu and select sound & colour -sys see the sound-sys / colour-sys is maching with your country transmitiongh sys {EXP.: PAL-BG / NTSC-DK /NTSC- MN /SCEAM- I ) IF your not set purfictly pls select AUTO colour sys and set automaticly set colour & sound .[see user's menual book and set your tv.]
Oct 06, 2009 | GE 35GT695 TV
My subwoofer on my philips 5.1 speaker system is constantly generating lots of bass noise even on mute.
I assume you are using XP. Try these steps.
1. Open 'Sound and Audio devices' in Control Panel.
4. Start playing a sound.
5. Set the volume control of the subwoofer to the middle position.
6. Open volume control and adjust Master volume to a comfortable level (i.e. until there is no hum).
Also make sure you haven't muted any sound device except microphone. I think your problem is you have set it to the maximum level. So decrease it.
7. Mute the sound and check.
Good luck! Let us know the result.
Jul 07, 2009 | Audio Players & Recorders
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
