Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Dish washer door leaks
The dish washer door leaks when running
  • 833 Answers
This sounds like a case of the water rising too high in the machine. If your unit has a float to control the water level (located in the wash area), it is likely stuck. Free it by letting water into the machine and then exercising it to get the 'goo' out. If it has a pressure switch located in the motor area, clean out the line.
Posted on Feb 11, 2008
Samsung dish washer won't stop running event with the door open no leaks no water anywhere pump pushes water out drain hose
if you can hear it running even with door open its probably in a fault mode as this the only circumstance in which it will run with the door open, what you are hearing is the drain pump and its doing that because there is a leak in the base of the machine setting off its flood switch, if you pull the dishwasher out and lean it back you will see water run out the bottom, then you need to find where its leaking from
Dec 26, 2016 | Samsung Washing Machines
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
Rise aid needed ever time we run the dish washer
if you are loosing all of your rinse aid there should be evidence of a leak under the door. if there is no leak then i would replace the dispenser.
May 20, 2012 | Maytag Dishwasher
Kenmore model #16761691 leaking at the bottom of the door. Where is the gasket located? Or is it another problem?
does it leak all the time or did it just start?try running it with nothing in it and see if it leaks,if the dishes were racked wrong the water can get deflected and leak out through the door,also,remove the bottom rack,look at the screws going around the bottom part under the wash arm,if any of those are loose it causes a wave in the dish washer and the water leaks from under the door.if it's leaking from one of the corners the gasket could be bad
Apr 17, 2011 | Kenmore Dishwashers
White film is all over my inside of the dish washer & dishes
This sounds like excess soap or not enough water. You may also have really hard water.
Turn on machine wait until it starts running see how much water is inside. there should be a 1/2 to 1" +/- in the bottom but not enough that the wash arm would be touching and not enough that the door would be leaking when you open it. This could also be a circulation problem set wash arms a certain way and observe that they have moved when you open after running for a minute or 2.
Please let me know if I can do anything else to help.
Apr 13, 2010 | GE Dishwashers
When washing dishes the dish washer leaks water? lots of water
it sounds to me like you need to check the seals underneath the dishwasher.
Oct 16, 2009 | Dishwashers
My frigidaire dishwasher leaks from the bottom right of the door. It forms a puddle while running a load of dishes. Looks like the seal is gone underneath the door on the right side. Any idea how to...
One possible solution to your problem could be as follows... Could have been little regular soap or something put in that made it suds up causing it to leak out of the front and sometimes not to drain all water out. Pouring vegetable oil into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem. Also could have a bad door seal. Check for any tares in the gasket.
Apr 11, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Kenmore dish washer leaks thru the door, need replacement seal.
I dont know what models but several models leaked thru the soap dispensor in the door.They were recalled. Check the manufacture for your model.
Jan 26, 2009 | Dishwashers
Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Oct 14, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Rinse aid used very fast and dishes not drying
Look for a blue or green streak on the door panel when you upen it to load the dishes. Does the washer sound different during the wash than it used to? If so your dispenser is leaking. This will also cause the water to suds up and not wash as well as it should. Start the washer with no detergent or dishes and let it run for 5 minutes, then open the door and see if there are a lot of suds in the water. Post back to let me know what you find.
Oct 20, 2007 | Whirlpool 24 in. ADP5966 Free-standing...
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
121 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
