Sony Triniton Fuse Blows
Hi I have a Sont trinitron KV G21S2,15inches.
Recently a fuse blew as I tried to turn the tv by pressing the main power button on the tv. As i pressed the main button I saw a small flash like explosion in the back.
I know how to read a circuit diagram and its components very well. I had a quick look but of a preliminary inspection found no capacitors blown.
The power supply seems to be pulling three amps and blowing the fuse, each and every time I put the tv on once I hve replace the fuse. Obviously there must be a short somewhere. There are four transormers on the board and i put my multi meter along the terminals and they are showing zero resistance. Do I have to pull the transformers out to get an accurate reading ?
I even tried just finding the same board to replace the whole board. But sony doesnt have any parts for this television anymore.
Im in a bit of a pickle. Please help.
    President:
  • 3,130 Answers
You will have to trouble shoot the board down to the component level I'm afraid. I would for sure pull out the transistors or the FETs to get a good reading on the parts.
Posted on Feb 11, 2008
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: sony trinitron KV G21S2(i think)
Id you have no TV repair experience, play it safe and take the set into an authorized Sony repair place to estimate the cost to repair. Yes I know it would be nice to repair, but how much do you know about component level printed circuit board repair? You will need to first get a service manual, know how to read a circuit diagram, thats a schematic, and know how every circuit works with each other to make the TV set operate. I do appriciate the fact you would like to repair this yourself, but there is no magic fix in most cases when it comes to electronics. There is circuit diagnosise involved. Best advice would be to call in a pro to assist you in these types of repairs. Good Luck
Posted on Jun 23, 2007
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron stayby light blinks 9 times. Unit
Theirs a problem in CRT board,the inner part of your TV,at the power supply section.Try to check fuse at power supply section.there are 2 fuse in the board.The AC fuse and the DC fuse check the DC fuse.
Jul 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega trinitron 32: kv-32fv16 will not come on any it was manufactured in 2000 can it be repaired?
hi,
Yes, it is repairable. Check the power switch and fuse. If the fuse is blown, try to replace it with same value. But if it blows on second time it means that there is a short circuit..You need a service technician to have it repaired.
Nov 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Is there a power fuse in this tv. sony 32" 1998 trinitron. Had great color, picture & sound. Will not turn on/no power.
There are fuses in most TV's... and in some cases, it's nothing but the fuse. BUT, the fuses are there to protect the circuits... so unless you know that there is nothing wrong with the TV, you shouldn't simply replace the fuse and plug it back in. However, if the TV is an older TV and it's either fix it by replacing the fuse or get rid of the TV... then I'd certainly take out the screws and check the fuses in the TV. But many times the fuse blows to protect it when something else fails... so if you find a blown fuse, look around for other signs.
WORKING ON ELECTRONICS should be done by professionals!! Proceed at your own risk!
Oct 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No power, stanby only
standby sont tv?...you need to open the back cover of your tv..check whether you fuse are blown/open...if yes,do not replace right away the fuse there might be a problem on the main supplys...using yuor multitester check your horizontal output transistor..it is located near the plyback transformer..if you do not now the correct testing of the transistor replace it with a new transistor...same with the regulator replace it with a new one...then replace the fuse ..your tv is now working again..
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony triniton,no sound or picture,flashing red light blinking!
the main problem of your tv set is the main power or what u call the regulator.the red light blinking it means your tv set is on standby mode.
Feb 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Triniton not powering on
If the lights don't come on the tv ,try to connect the tv to the other power point
and check if it powers on, if its does not power on then its the problem with
fuse inside the tv replace the fuse and check its works ...and also test the power chord for continuity ..
Good luck...
Feb 18, 2009 | Sony KV-27FV16 TV
TV shut off Sony Trinitron KV-32S20
I believe this uit has a fuse on the AC input on the main PCB. Yu probably blew that fuse.
Jan 16, 2009 | Sony KV-32S26 32" TV
Blowing Fuses
main rectifier could be shorted, main regulator could be shorted MOV surge supressor is probably shorted. MOV will be a little disc close to the power cord input (after fuse).
Jul 31, 2007 | Sony KV-32FS13 TV
Sony trinitron KV G21S2(i think)
Jun 23, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
