Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Wir I recently fixed my starter motor as it was holding on by one bolt the other bolt was still holding the broken part of the aluminium casing to the bike.This needed to be welded back on so that now it is fixed to the bike by two bolts as it should of been.Upon replacing wiring I may have put the voltage regulator earth wire to the main circuit breaker copper stud located under the oil tank.When ignition turned on the neutral light ,oil light ,full beam began to dim and brighten all in a intermittent fashion.and it also caused the wiring to the starter switch to heat up.It also making a click noise somewhere near the ignition each time it dims.Please help me PLEASE
  • blusmom May 25, 2008
    trying to replace the starter solenoid in 1990 fxr
    Novelist:
    Champion:
  • 202 Answers
Please do check for improper grounding of the wires...
there seems to be an extra ground for the wire to the starter switch...Please do check the full wiring, with a proper diagram
Best of Luck
bye
Was my tip helpful?
Posted on Feb 17, 2008
How to take the starter off
Always disconnect negative battery cable first. Then take off the battery connection at the starter, and any other wires to the starter motor and solenoid on it. Note where connected at. Then unscrew the starter bolts and remove starter. Usually 2 mounting bolts, sometimes a third, or a nut on a stud in some cases. Also a few have a small mounting bracket to help hold the starter firm, no mind, just get everything loose and off to remove the starter.
Nov 30, 2016 | Cars & Trucks
How to change my starter? I have a 2004 HD Dyna Low Rider
Hi Hannah, start by disconnecting the battery, negative cable first. Then drain primary oil and remove primary cover. Bend the locking tab back that secures jackshaft bolt and while holding pinion gear unscrew and remove jackshaft bolt, locking tab and thrust washer. Then remove rear exhaust pipe to gain acess to starter. Disconnect all wires and cables from starter. Remove chrome starter end cover. The two bolts that hold the starter motor to the engine case are 5/16" allen heads. Now my memory is a little fuzzy since I have been out of the business for several years, but if you can procure a long straight ball head allen key or socket I think it will allow you acess to the bolts without removing the oil tank otherwise you have to remove the tank. Once you get the two bolts out you can remove the starter. Replace starter in reverse order, tighten starter bolts to 20 foot lbs. of torque jackshaft bolt 100 inch lbs. of torque. primary cover bolts 10 foot lbs. of torque. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 04, 2015 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
Power folding mirrors
they are bolted on thru the inside of the doorframe..take that trim off inside and you should be able to acess the mount bolts there
Dec 26, 2013 | Land Rover Cars & Trucks
How to replcae the starter
o remove:Disconnect battery negative lead.Disconnect positive lead and connector of starter relay.
Remove three fixing bolts from starter motor. Top bolt also holds the cable support.Slide starter motor to rear, turn and lift upwards.To reinstall:Transfer locating bush to new starter motor.
Reinstall in reverse order.Torque bolts to 50nm.
Oct 06, 2011 | Cars & Trucks
My starter is moving around and the bolts are tight what could it be?
the motor is loose on the two bolts that hold the windings ,best advice is to buy another motor from the scrapyard and just change it because if these two bolts are loose then no doubt its past its sell by date for repairing
Jan 27, 2011 | 1999 Chevrolet Blazer
Ho w do i replace starter to a 1998 trooper and where is it located? pictures would help.
Read here before you replace the starter.
Bear in mind that the starter solenoid usually fails long before the starter motor itself and is a much cheaper repair.
Starter is on the LH rear of the engine.
NB!! : Whenever you work on the starter first remove the battery negative cable.
On V6 engines remove the LH exhaust downpipe(1).
Remove heatshield(3), 2 electrical connections and then the 2 bolts that hold the starter to the transmission.
On 4 cylinder engines it is possible to remove the starter by just removing the 2 electrical connections and then unbolting the 2 bolts holding the starter to the transmission. In this case an assistant is nescasary to help with holding the nut in the engine bay while you unbolt from the bottom of the vehicle.681bb13.jpg
Sep 23, 2010 | Isuzu Trooper Cars & Trucks
I recently installed a speedometer on my 05 sportster and it will not light up or display mileage, nor will it showmph while traveling. any ideas on what may fix this problem
Hi Bon_joby, always check your instrument fuse before performing the next procedure, try cleaning your speed sensor located on top of the transmissions right side between the top cover and the chrome starter end cap on Twin Cams and on top of the engine case between the rear cylinder and the starter motor for Sportsters. Remove the the bolt that secures the sensor and pull it out of the transmission. Inspect sensor for obvious damage and repace if necessary. If sensor has no damage then wipe clean any obvious contamination like micro fiberous material with a clean rag and reinstall, torque bolt to 8 ft lbs. Next check the connector to the speedometer for correded, broken or loose pins/sockets. If your problems still exist try replacing your ignition relay if your year and model has one. Good luck and have nice day.
May 12, 2010 | 2005 Harley Davidson XL 883C Sportster...
Starting motor binding/grinding
I will try to help. As you describe the problem I wonder if the starter gear is not cut deep enough to give clearance on the flywheel or the end bushing is too short. A short bushing would allow the gear to travel too far on the starter shaft and smack the flywheel.
Also the flywheel position would change if your particular motor has thrust washers on the crankshaft.
You may not know if anyone milled the starter case or motor. Maybe if you ground off the tip of the bolts it would help.
Apr 14, 2010 | Boating
Starter motor is not engaging, I think it is a problem with the bendix, is it easy to remove starter motor
on the 2 stroke models its a PITA
<br /> <br /> sadly enough there is alot to do to get to the bolts easily<br /> <br /> <ol> <li>take off pullstart not the front few bolts that hold the cord but the ones on the case behind those.<br /></li> <li>you will now see 2 bolts under the flywheel to the left bottom those are the front starter bolts.<br /></li> <li>Take off clutch cover and clutches (may be able to get away with just the front clutch) and you will see the rear starter bolts.</li></ol> not so hard with the right tools and dont bother with the skid plate.
Mar 04, 2010 | Polaris ATV
Lands Phones Logo
163 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
