Question about Cell Phones
Downloading music into Kingston 2GB SD card on Nokia 6234
I am having difficulty downloading a AAC music file onto the Kingston 2GB SD card installed in NOkia 6234. I get 'corrupted file' error message on the phone when I go to play it.
    Brigadier General:
  • 3,614 Answers
It's possibly not properly formatted type of AAC file that uploaded into your cellphone, that when you try to play the cellphone cannot support to play it and that it gives a messages like corrupted type of file..
Hope it helps
Enjoy!
Pls. rate and hope to hear more from you
tnx
-micro
Posted on Feb 10, 2008
I loaded songs to an sd cad - my computer will play them from the sd card - but when i put the sd card into my nintendo dsi xl,press the sd icon on ds - the screen says "cannot find any music...
hello, Computers can play any audio formats (ex:- MP3) if you have right codecs installed, but the Nintendo is made to play music in AAC audio format only.
so you need find a program to convert your music.for example the music files are in MP3 format you will need to find a program that converts MP3 to AAC format.
Feb 27, 2011 | Nintendo Video Game Consoles & Games
I've Been Syncing Music Onto My Micro SD Flash Reader With No Problem Until Now. It Keep Saying Can't Create or Copy Certain Files Because The Disk Is Write-Protected and Would Like To Know How To Remove...
On the SD Card adapter housing for a Micro SD card, look along the edges and you will find a small tab. This tab slides back and forth to either lock or unlock the card. It is for write protecting you files.
Feb 25, 2011 | Kingston MicroSD 2GB (2 Gigabyte) Card for...
How do you download music on a dsi
Hello sherribaxley
As far as I know, there is no direct way to download music onto your DSi. In order to listen to songs on your DSi, you will first need to copy the songs you want to listen to onto a compatible SD or SDHC card. Not all songs are compatible with the DSi. Some songs may be copy protected and will not work. The DSi is compatible with AAC audio files with a filename extension of .m4a, .mp4, or .3gp.
WHAT YOU'LL NEED
- A compatible SD or SDHC Card. The DSi is compatible with SD cards up to 2 GB and SDHC cards up to 32 GB.
- Compatible music files stored on a PC or MAC.
- An SD Card slot in the PC or MAC, or an external reader/writer
WHAT TO DO
1. Insert the card into the slot.
2. Open Windows Explorer (for PC) or Finder (for Mac) and select the drive being used by the card to open it.
3. Open another instance of Windows Explorer or Finder and navigate to where the music is stored.
4. Highlight the desired file(s) and/or folders, copy them, and then paste them into the first instance of Windows Explorer or Finder to create copies on the card.
If you need to convert the format of your music files, there are many freeware applications available to download on the web. I personally would suggest using iTunes, as it has a built in AAC converter.
Hope this helps. Please don't hesitate to contact me should you require any further assistance.
ajblaj
May 03, 2010 | Nintendo DSi Matte Blue Console
I downloaded music onto a sd card but the dsi will not read the music on the card
Your music has to be from i-tunes or it has to be AAC file. Good Luck :D
Dec 13, 2009 | Nintendo DSi Black Console
How do you play music saved on an SD Card?
1) frm da music on iTunes, right-click,then click on CONVERT 2 aac.another track(identical) should come out.
2)after completing step 1, go 2 my computer nd open the SD card up,create new folder or use da one u used 4 ur other music.
3)after step 1&2 copy nd paste ur song(s) to the folder u had open.hope dis helped
P.S. make sure u converted ur songs 2 AAC(aac) or else it wont work.
Nov 08, 2009 | Nintendo DSi Black Console
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
Can't put music on my microsd card from my windows media player
i can't put music on my micro sd card from my windows or on my pc.
Apr 20, 2009 | Kingston 2GB Secure Digital Memory Card
2gb SanDisk Micro SD Card only holding 500mb.
I believe the Drive has gone Bad. It does happen where the system thinks th e whole drive is there, but the internal hardware just cannot access it.
Aug 07, 2017 | SanDisk 2GB microSD Memory Card
Transfering Music from PC to Samsung Envy SD card
yes you can using wrong file format. you can insert music on MP3 format type support to the mobile.
Mar 18, 2009 | Samsung SGH-d807 Cellular Phone
Downloading music from my pc to phone
This is the same deal with a lot of other people, including myself. You need a smaller SD card to transfer anything. The problem I've had is getting Windows to recognize my SD card when I insert it into my laptop. But the first issue you'd have is with a 2GB card, which isn't recognized in the SLVR. Also, some cards aren't compatible with Windows. Cheap ones like Transcend have issues being read and formatted by Windows, cause they're cheap to begin with. Get something from perhaps Crucial or Kingston. You're better off with a good brand anyways.
Jan 15, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Cell Phones Logo
131 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
