Question about Acer Scan to Web 3300U Flatbed Scanner
Benq scanner I have a BenQ Scanwit 2720S film scanner. Was working OK but now in preview mode only scans in the first frame or slide. Has anyone experienced this problem and tell me what is happening? Any advice gratefully received. Thanks Rod i have received scanner error [ffff:0064]
    New Friend:
  • 166 Answers
Did you try to uninstall driver completely and fater did you reinstall the driver ?
Posted on Mar 21, 2008
Is it possible to scan colour slides with the BenQ scanner U5000 ? May I receive a user's manual for BenQ scanner U5000 ? Thanks!
There IS a prism device that diverts light from below up and through the
film/slide. I've heard no good reviews of these, though. Quality seems to
be quite poor.
There does not seem to be a manual on the Benq website maybe go there and request one by email.
Apr 30, 2011 | BenQ Scan to Web 5000U Flatbed Scanner
SCSI to USB conversion for Film Scanner
SCSI to USB converters are available, but I doubt they will be of much help for you, you'd still need a special driver for your scanner.
Windows 7 Professional, Enterprise, and Ultimate support "XP Mode", essentially a Windows XP environment running in a virtual machine. I'd try to get the SCSI interface card and scanner to run inside the VM as a workaround.
Feb 07, 2010 | Acer ScanWit 2720S Film Scanner
Computer restarts when trying to aquire photo's
go to control panel, then system,advanced tab, startup and recovery. look under startup and recovery then uncheck the block that says automacilly restart then ok. you are experiencing a software- hardware failure and when you do this you may be able to provide enough info to lead to the repair. could be as simple as an incompatible driver
Jul 06, 2009 | BenQ ScanWit 2720S Film Scanner
OVT scanner does not calibrate nor allow "acquire picture"
I had a similar problem. Driver of scanner was ok.
Went to configuration->device manager-> in list checked the USB controllers and updated the Enhanced usb2 controller. Reboot and re-install de scanner driver. Most likely this will solve your problem
regards, Andre
Jun 20, 2009 | BenQ ScanWit 2720S Film Scanner
Scanning Size
Do not try to change the scan size, change the resolution. The window that appears when you want to scan should have a resolution (DPI) area that can be changed. IE: 300 DPI to 800 DPI. This changes the picture size.
May 16, 2009 | BenQ ScanWit 2720S Film Scanner
Where can I find Linux drivers for BenQ Scanwit 2720s?
sudo apt-get install sane
Then visit this web-page to learn about Benq (formerly Acer)
http://www.sane-project.org/sane-mfgs.html#Z-BENQ
Apr 11, 2009 | BenQ ScanWit 2720S Film Scanner
Driver for scanwit 2720s
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/Benq/Benq-ScanWit-2720S-2012.shtml
Mar 19, 2008 | BenQ ScanWit 2720S Film Scanner
Scanner incorrectly reads frame position on film
Yes there is
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Acer Scan to Web 3300U Flatbed Scanner Logo
306 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Marvin
Marvin
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
