Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
HEY MY TV IS NOT TURN ON
I PUSH THE ON KEY AND NOT TURN ON AND A USE THE REMOTE
AND IS LIKE NOT HAVE POWER I TAKE OUT ONE FUSE AND A CHANGE IT BUT JUST BURN IT
WHAT A CAN DO?
  • Philips Master
  • 5,138 Answers
Unless you know how to repair televisions nothing! Set will blow fuse as long as you have something shorted probably hori output Transistor.You need to take this to a repair shop this is not a problem you can fix at home.ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 10, 2008
Not playing NTSC DVDs
I can see if there is an unlock code for your device
Apr 21, 2008 | Yamaha DVR-S150 DVD Player
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Can't turn tv on at all
Hey Deon, this is very broad and could be several reasons. First off is there power to the tv? Usually tv's, even when they are off, have a light on the power button on the tv panel. Forget the remote for now and push the power button on the tv panel. Does any light come on? If there is no light at all then it has something to do with power. Check your outlet and see if there is coming through there. Could a be a fuse. If there is power through the outlet but no power on tv means something wrong with the AC on the tv. You should then contact tv repair or send it in under warranty. Read no further if light does not come on.
If a light comes on then try changing channels by pressing buttons on the tv panel. Secondly, try changing the input. It could be possible that it is on a different input and therefore, seems like it does not turn on. At the same time turn up the volume (all from the tv panel) to see if any sound comes out. If there is sound and still no video then try to change the contrast and brightness through the settings on the tv. If you see no menu then probably the lcd panel might be gone. Then you need to contact manufacture/ tv repair shop or send it in under warranty.
Oct 23, 2013 | Emerson Televison & Video
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Trying to program xbox360 universal remote. found
hey christy, to turn the tv on first push the desired device button like tv from the options tv,vcr,dvd etc. and then press the power button on..!!
it should work
Dec 14, 2009 | Microsoft Xbox 360 Universal Media Remote
Codes to program the RCA Universal remote control for a Magivox T.V.
My dear friend if your remote control got the code search button try with this.
Push and hold code search button until the led stand lit,now release him push and release the tv button the you need to push and release the power button until the tv set turns off push and release the button set and the code get in the memory of the remote.
You need to turn the tv manually.
Good luck
Sep 13, 2008 | Televison & Video
TV WILL NOT TURN ON
  • please check
  • fuse
  • loose connector or parts in power supply
  • power regulator might have failed.
Oct 22, 2007 | Audiovox AVT1498 TV
Lost code
what make & model
Oct 12, 2007 | Zenith B25A24Z 25" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
