Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
AKAI PT55 Is it possible to adjust the green lines. I can adjust the convergence for the red and blue with the remote. Just not the green. I no longer have the manual. It is an AKAI 55" projection tv. All help much apreciated. Jon
  • jon28205 Feb 10, 2008
    How do you adjust the green convergence through the service menu?
  • Samsung Master
  • 8,617 Answers
The green convergence can only be adjusted through the service menu
Posted on Feb 10, 2008
  • Sonny Berry
    Sonny Berry Feb 10, 2008
    there are 5 different menu codes for Akai depending on models I will post all 5. just be sure to write down anything you change so you can revert back if you have too.
    Akai
    TVs :
    • Turn the TV off.
    • Press and hold the {VOL+} & {VOL -} buttons
      on the TV and then turn the power on.
    • The Service Menu will be displayed.
    • Use the {MUTE} and {0-9} numbered buttons to access modes.
    • Use the {VOL+} {VOL -} buttons to change settings.
    • To exit, turn the power off.
    #2 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    • Turn the TV on.
    • Press the {F WHITE} {AUTO} {V CHIP} buttons on the remote.
    #3 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    • Turn on the display and select the input that you want to adjust.
    • Turn the display off.
    • In quick sequence on the remote press:
      {MUTE} , {1} , {8} , {2} , {POWER} buttons.
    • The Display will turn on with the service menu displayed.
      ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
    • Select the function and use the {VOL+} to enter the next screen.
    • Save settings and exit by pushing {MUTE} twice then {POWER}.
    #4 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    • Turn the TV on.
    • Press the {MUTE} {OK} {TV} buttons on the remote.
    • Use the {UP} {DOWN} buttons to select options.
    • Use the {RIGHT} {LEFT} buttons to change settings.
    • Press the {OK} button to save settings.
    • To exit, press the {TV} button.
    #5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    • Turn the TV on.
    • Press and hold the {VOL -} button on the TV.
    • Press the {MENU} button on the remote,
      release the {VOL -} button on the TV and
      then press the {TV} button on the remote.
    • Now to access the Service Menu, press the {i} button.
Blue and red wavey lines and distorted picture
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 20, 2010 | Toshiba 53H71 53 in. Rear Projection...
It appears to be convergence issues. Red, green,
May 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Color is distorted. Green, red, and blue ghosts
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
Jul 15, 2009 | RCA P52950 52" Rear Projection Television
Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba 41h81 green convergence problem
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
  • Screen looks 3D
Apr 07, 2009 | Toshiba 42H81 42" Rear Projection...
Akai
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 31, 2009 | Akai PT4298HD Rear Projection Television
Akai PT4799HD - Bluish and Distorted Screen
  • Screen looks 3D
Mar 01, 2009 | Akai PT4799HD Rear Projection Television
Fuzzy Blue...?
these set are bad about the blue tube messing up.. what happens is the convergence board witch generates alot of heat cooks the blue glycol.... basically growing algea in the blue tube... it is possible to remove the tube.. and remove glycol and clean the tube then replace and adjust..i have done a few here at the shop
Mar 14, 2008 | Akai PT4298HD Rear Projection Television
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
109 people viewed this question
Jerry Greenberg
Jerry Greenberg
