No BLK and Yellow
My bubble-jet 6000c printer can not printout blk and yellow color even I replace teh new ink.
  • mikehuang Feb 13, 2008
    It's Canon BJC-6100, I did the cleaning and deep cleaning also replace inks(BCI-3cBK, BCI-3eY). Still no Black and Yellow ink from printer head, I guess the head already been clogged. So I soak it into the hot water for about 1 hour and cleaned it with soft cloth. It still doesn't work.
    Thank you
    Mike Huang
  • mikehuang Feb 14, 2008
    Any special cleaning solution for inkjet printer head?
    Mike
    Sergeant:
  • 390 Answers
More info please mikehuang,
When you replaced ink, did you reset ink settings. Do this if not. Also i recommend a thorough cleaning to make sure ink is running out well and heads are not blocked. cheers lilacgerry xxx
Posted on Feb 10, 2008
  • Geraldine Watts Feb 14, 2008
    I would not use hot water ever but this is just my opinion. The only liquids i let near any printers or parts is proper cleaning solution and unscented wipes likr the ones you use for babies. Have you actualy used cotton tips and proper cleaning solution to clean by hand the area where the cartridges contact the printer, not the cartridges. Clean until no more ink stain appears on cotton tips then try again.
  • Geraldine Watts Feb 15, 2008
    I cannot help with specific names of chemicals, a si have aalways just used the pink no brand name one included in my woolworths ink refil kit. I see alot of people usinf the terms isopropyl alcohol but i am unsure if this is what mine is. My experience with metho and basic alcohol products are not favorable. good luck.
Why wont my printer print in blk?
take the black cart. out and dab on a wet paper towel, unplug printer and use q tip to clean the print head where the cartridge goes with alcohol, if that doesnt work you have a bad cartridge
Nov 09, 2015 | Office Equipment & Supplies
My printer gives me the message: "Out-bin Full" all the color ink cartridges are empty, blk one is full I am using Staples all purpose printing paper What needs to be done?
"Out-bin full"normally means that the printer thinks the paper tray where the printouts go is full of prints. If you have printouts on the machine, remove them. If there are no printouts, then check where the paper comes out, to see if there is any small piece of paper jammed, or if the sensor is stuck. The sensor is normally a small piece of plastic on a hinge, which will be just where the paper exits the printer.
Jul 23, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
The color yellow does not print., both color and blk ink cartriges are new
Make sure the color nozzels are clean, sometimes the get clogged.
May 29, 2010 | HP DeskJet 820Cse Printer
What colors go where sony cdxf5700 install to
The aftermarket wiring colors are universal so this is for your Sony
Battery ---yellow
12 volts accessories-----red
Blue/White---- amp. Turn on
Blue---antenna turn on
Orange—illumination
Speakers wires are white;white/blk----green; green/blk---purple; purple/blk---gray; gray/blk. Now for your car I need to know the model
Jan 01, 2010 | Car Audio & Video
S900. Amber power light flashes 7 times then green once. unable to get any further, any ideas please GG
Probably the waste ink tank is full.Try this:
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
You are now in Service mode.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
Oct 07, 2009 | Canon Bubble Jet S900 InkJet Photo Printer
Why does the entire photo printout with a pinkage color overlay when indicating using glossy photo paper, even different photo paper. This occurs with several different programs not just Photoshop. I've...
That happens if you put photo cyan where the plain cyan ink should be, also photo magenta is too weak to be used in the magenta slot. I've also seen generic inks that weren't the right colors.
Jul 09, 2009 | Canon i9900 InkJet Photo Printer
152 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
