Purchase of washing machine
I want to purchase a fully automatic electrlux washing machine. What is the difference between holeless drum and one which has holes in drum?
Whis is latest technology? Which is better (7 kgs model or 5.5 kgs model) in India?
    Genius:
  • 3,587 Answers
Well...the hole less drum has more concentrated spin/wash water solubility. The hole drum has a more effective rinse release cycle. The holeless drums are usually used for higher weight loads, since the water penetration on those can be critical. Water capacity and usage are key to this choice. It all depends on the availability of clean water in your district.
Posted on Feb 10, 2008
Water is not stop automatic
Do you mean: The water continues to run into the drum? If so you need an appliance engineer to check out the incoming water solenoid valve.
Nov 06, 2014 | Washing Machines
I have an akita fully automatic washing machine . its not working , but i do hear a sound and the motor gets hot. What may be the problem.
open the door and try to turn by hand the tub! if it goes easely maybe the belt is broke. if you have a hardtime to turn it maybe your motor is burn and stock! take of the belt and try start your W/M.. see if the motor run!!! in other case that can be the drum (out of is axe) or something stock Under the drum!... good luck
Oct 05, 2014 | Washing Machines
Why is the Panasonic NA-F70B3 on its very first test wash started rattling really loud and banging on the side of the machine Casing
Any loud rattling sound is bad news. The drum should not be banging on anything!! Return or file a complaint with where you purchased it immediately. Do not wait, there will be a time-limit on returns and after that you are on your own.
Jun 14, 2014 | Washing Machines
My fully automatic lg. washine machine when i load the clothes it will wash for a few seconds and it will stop and continuous beeping why?
It can be due to load trip off , check with a lighter load.
Also check for free movement of the drum and bearings, if not you need to lubricate or release the friction on the drive.
Feb 07, 2013 | Washing Machines
Hello,my fully automatic washing machine samsung is showing de when i on star the power switch ,it works without clothes but when clothes are inserted it shows the de display,why is it happening?
It's a bit unusual to have the difference between with or without clothes but 'de' normally stands for Door Error! There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
PS All I can think of is that the clothes make the drum/rubber surround drop sufficiently to trigger the 'DE'- strange!
Mar 21, 2011 | Samsung Washing Machines
I acidentally washed my daughters snuggy in the fully automatic washing machine( ) , the snuggy broke out and all the jell, cotton are insde the machine. i removed all sort of visible items from the tub....
Nothing to worry as long as the drum is not damaged, which should not be the case as it is only cotton and gel. Run the machine empty with hot water two to three times. Make sure that the water outlet is not blocked with the cotton.
Dec 06, 2010 | Samsung Washing Machines
The agitator spins automatically(not the drum)when the power is switched on and stops only when power off in the top loading fully automatic whirlpool washing machine
If you saying that the machine agitates when ever it's plugged in. You will most likely have a bad timer. You will find that the points are welded together inside the timer
Nov 17, 2009 | Whirlpool Washing Machines
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
