Question about Sharp AL-1551CS Printer
H 4 error
I moved my Sharp Al-1551CS from one house to another very carefully. It worked before without anty problems. Now when I went to Start it up again it shows me a H 4 error and keeps blinking. Please Help!!
  • crzybones Feb 10, 2008
    found the fix on this site.
    trickieone
    Rank: Guru
    Rating: 87%, 117 votes
    Add to Buddies
    Try this, it should reset your machine.
    Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
    1. Find the pink Clear button on the Control Panel of the WorkCentre.
    2. Find the button below the word Auto.
    3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
    4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
    5. Press the green [Start] button.
    6. Press the pink [Clear] button two times.
    7. The WorkCentre should now warm up and come to ready.
    8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time
  • 168 Answers
If the Reset does not work, then you have a fuser error and your machine will need service.
H4 is a fuser heating error code.
Meaning the machine is not warming up because of a bad lamp, thermal fuse, thermostat, and or thermister.
Hope this helps.
Good luck.
Mac
Posted on Feb 10, 2008
Why is my Sharp AL-1551CS displaying error h4?
replace the fuser, do not continue to reset or the machine can catch on fire try this site a fuser unit as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 13, 2015 | Sharp AL-1551CS Printer
I have a Sharp AL-1551CS that when turned on shows an error message and will not work. The error code referenced in the maunual says to remove the shipping screw. I have had this unit several years. what...
instead of a screw, some models have a dial to lock the scanner for moving machine. look above where the paper exits machine twords the left side under the scanner assembly for a dial switch and turn it.
Nov 11, 2009 | Sharp AL-1551CS Copier
Sharp AL 1551cs reading L
I also have an AL-1551CS copier...normally the "L" has something to do with the scanner lock device underneath the left side of the top part (ie; the scanner) It's clear colored and round with protrusion to turn it from locked to unlocked...this is for moving the copier so the scanner (lamp and mirror assm) won't be disturbed. Use a flashlight or such to inspect the position of said device (ie; locked or unlocked) insure it is unlocked.....power back on and tell me if there is a number following the "L" Tim
Jul 03, 2009 | Sharp Office Equipment & Supplies
My al-1551cs sharp printer displays L1 and nothing works
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Jun 09, 2009 | Sharp AL-1551CS Printer
Copier mod AL-1551CS gets a E7 error code and lock up. Whats up?
The E7 code is related to the laser and or the distinction between black and white being read/interpreted by the system. There should be a sub code which will point more directly to the problem. The laser could be bad or the glass and mirrors need cleaning. Remove the glass (with the copier unplugged) and clean including the white strip underneath, clean mirrors too.
Mar 20, 2009 | Sharp AL-1551CS Copier
Error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Jan 17, 2009 | Sharp AL-1551CS Copier
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
Al-1551cs / L!
Sharp Error Codes
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Sharp UX-170 maintenance mode: Turn power on, set the line selector at "T" (tone), turn the program switch ON, then press 9 * 8 # 7. Select the next entry from this list: 01 all black copy, 02 ROM/RAM check, 03 auto feeder mode, 04 aging mode, 05 panel check mode, 06 G3 transmission, 07 check pattern, 08 product check (includes diags, 06, 03, 09), 09 signal send mode, 10 memory clear, 11 led array on mode (lamp), 12 product program sw mode, 13 telephone number list printing mode, * soft switch mode, # transmission level. This same procedure works on similar, older models that do not have an LCD display.
Sharp UX-2100 often has power supply problems which cause the unit to lock up.
UX-3200/FO-3250: FO32TD toner/developer costs less than UX30TD and will work in the UX model if 2 fins are broken off so that the unit can be installed in the UX model. Similar duplicity exists with many Sharp laser supplies.
Sharp FO-4800: fuzzy print often results from a bad Motor PWB (polygon mirror) #RMOTN0020GCZZ located in the optical unit.
Nov 06, 2007 | Sharp AL-1551CS Printer
Sharp AL-1551CS Printer Logo
309 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
