Question about Yamaha RX-V630 Receiver
Remote I havn't used the unit in a while and the remote is not working(even with new batteries). The amp is working fine. Thanks Matt
  • 1,512 Answers
Hold the remote up yo a video camera and you will see code flashing from the LED in the remote. If it is dark, the remote is faulty. A common fault is for the ceramic resonator(orange pack) either dry joints(it is a resonator) fractured wires, or just fail with no reason, thus rendering the clock for the main proc. not working. Another common fault is the LED being dry jointed. or the LED faulty. All of these easy to fix. Sometimes the power supply may fail to the detector on the front panel of the amp, The detectors sometimes go. all these things to be checked, but check the remote for infrared light with a camera first. Good Luck, a rating of "FixYa" for these technical tips would help my profile, Cheers
Posted on Feb 10, 2008
  • Graeme Ross
    Graeme Ross Feb 10, 2008
    oh and of course the silly battery connections. dry solder joints or get corrosion on them. A good clean and re-solder often helps with dead remotes.
How do I re-program my Remote Control with automatic starter on my 2009 Town and Country Van
My experience with frequently-used vehicle remotes (any make) is this:
1. When relatively new or in good condition, if remote stops working, the button battery inside is dead or too low.
2. If battery is new, & remote still doesn't work, a solder joint on the circuit board inside may have come loose or broken.(You can try re-soldering using a low-heat pencil iron & thin RESIN-core solder -- even if you're not great at it, what do you have to lose?)
3. It's rather unusual for even an older, well-used remote to simply lose its programming.If this is the problem, it may be cheaper to buy a new after-market remote (or pair of remotes) that you can program yourself (only works with some brands & years of vehicles, so READ THE INSTRUCTIONS ON THEIR WEBSITE BEFORE BUYING AN AFTER-MARKET REMOTE), instead of going to the dealer for a normally HIGH-priced programming job.
4. Used OEM remotes that match yours exactly (check the part # of your remote & the used one you're considering) can often be purchased from a local auto wrecker (now called "auto recycler") for cheap ($5 to $10 is common), but will need programming.I always go thru the many they have, looking for one that appears new or like-new.
5. IF YOU MUST GET PROGRAMMING FROM A DEALER, usually it's the SAME PRICE whether you have 1 remote or several remotes/keys programmed at the same time.Since dealer programming is pricey, I always have 3-4 remotes and/or chip-keys programmed at the same time.(My dear wife loses chip-keys & remotes from time-to-time, so I keep a few spares on-hand.I've found inexpensive after-market chip-key blanks at some key cutters and/or auto parts stores, altho they still require programming after the copy is cut from yours.)
:Some OEM anti-theft systems require that ALL remotes & chip-keys be programmed/re-programmed at the same time, whether they're original, used or new.Determine this IN ADVANCE, so you know what you're faced with.The good news is that for those vehicle manufacturers, dealers normally don't charge more to program/re-program multiple remotes and/or chip-keys, if all are being done AT THE SAME TIME.
6. If all else fails & you MUST buy a new OEM remote (which will require programming), try 2 things -- First, see if the dealer will make you a package deal on buying the remote (or 2 remotes, or a remote & a chip-key) AND doing the programming for a lower combined price.Second, it may be cheaper to buy a new OEM remote from a dealer who's had one in stock for a long time & wants to blow it out (or buy from online OEM seller) & then pay the normal programming price.See the CAUTION above.
There are lots of options here, so hopefully something is useful to you.
Feb 23, 2015 | 2009 Chrysler Town and Country
I have bought a GE cordless phone model 29670, base unit working fine but cordless unit no sound or display even though battery charged more than 10hrs before first use.
I took the phone to the shop where I purchased, they replaced the battery cordless unit with a new one, now it is OK. All displays are perfect.
Thanks & regards
Oct 13, 2009 | Uniden Cordless Phone
05 corvette push button start wont work and batt is not dead it worked fine all day then when I got home it stoped working all of a sudden. when I push it all the lights come on and so does the ignition...
Jul 21, 2009 | 2005 Chevrolet Corvette
Wii remote works with normal batteries but not with battery pack
same poblem if this is solved cud somwon plz send me the solution to cheers
Jun 30, 2009 | Nintendo Wii Remote Controller
Cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
Even with new batteries, remote does not work
Store manager suggested purchasing a new remote at $70. I requested asking the manufacturer for repair. Feedback, repair more costly than new remote. I opted for buying a new DVD player, not goodmans, for $100. Thanks.
Jan 18, 2009 | Goodmans DVD2100B DVD Player
Yamaha RX - V463 Reciever
Just on the basis of your description I would say that the unit is faulty. It might have something to do with the overload circuits inside the amp. The remote is not great even on mine, but I use a logitech harmony 785 to control my setup so it's not really a problem.
Sep 08, 2008 | Audio Players & Recorders
Replacement remote control
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
Jan 03, 2008 | Philips Magnavox DVD/VCR Dual Player
Yamaha RX-V630 Receiver Logo
111 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
