Yellow prints does not work.
Hi there! when i print a photo, the colors are all bluish. i cleaned the head and then deep cleaned again but to no avail, after putting it to nozzle check the printer does not print the yellow colors at all.
please help me. all the ink tanks are full. are there any other way to clean the head perhaps manually by taking out the printer unit head.
thanks in advance
islam.
  • 2 more comments
  • islam786 Feb 10, 2008
    thanks lilacgerry.
    it sounds very promising. i am just going to give a try.
    by the way, i have this canon i990 bubble jet.
    and heyy! thanks a trillion for such an instance reply.
    islam.
    hello lilacgerry.
    thanks so much for your initiative, but after so much of trying the method, it was all in vain dear. the yellow is still not working and the others are fine. i dipped the head in warm water for more than an hour, pressured forced water then did the auto deep clean for several times too. now the bluish is dissapeared but the surface of the yellow color is still whitish, no yellow color at all.
    now what do u suggest me my friend?
    hope to hear from u again.
    again thanks in advance
    islam... india.
  • islam786 Feb 11, 2008
    hi lilacgerry!
    i have a canon i990. which works with seven cartridges. all others are
    printing well, but just the yellow one doesnt, i even tried replacing
    another yellow cartridge but even that didnt worked out. i have deep
    cleaned several times automatically and yesterday as u said i even
    tried manually. i took out the whole printing unit dipped it in hot
    water, cleaned it with cotton, pressured it with forced water then
    again with air blower and after all this i inserted back the whole unit
    as it was and gave a deep clean again. after all this i tried to print
    but still no sigh of yellow prints. i use refill ink and i do it
    myself. never was a prob but this time. do u suggest me any chemical(s)
    which will help me ? and how should i use it?.
    but first let me thank u so very much for all the initiative u r taking
    in guiding me, i mean who does so often for an unknown person and that
    even without any charges. what caring type of persons are you'll
    afterall?
    islam.
  • islam786 Feb 15, 2008
    hi lilac!
    hope u r fine. yes my printer is atached to a pc. thanks for forwarding
    my prob to the canon and also for keeping my little secret ;) the
    solution what u r giving me seems to give a kick but i guess i might
    not be doing it in a right way. apropos! i have come to learn that
    isoprophyl alcohol helps in unblocking the heads, is it right? if then
    what is it, an alcohol or a chemical?
    should i go for it?
    dear lilac, i will be going out of station tomorrow and will be back on
    23rd feb, i can only fiddle with my printer on the 24th. meanwhile dont
    give up for me plleeaaaasssseeee. i will try to check my mails on the
    move but i doubt if i get a cybercafe where i am going. i will
    definately get in touch with u when i'm back. i dont know how this
    fixya.com system works but just in case then here is my mail add : islammohammed786@yahoo.com
    thanks again my friend, wish ya all da cheers
    islam.
    Sergeant:
  • 390 Answers
What printer do you have???? It sounds like the yellow part of the head is blocked or an air bubble. New cartridge or refilled or do you do your own. Need more info to help you. Manual clean by you may be needed. Cleaning with proper solution and cotton tips where cartridge contacts heads/ points may solve issue.
Posted on Feb 10, 2008
  • 1 more comment
  • Geraldine Watts Feb 10, 2008
    Ok, hope it works a traet for you, you ate welcome. I hate it when people cannot get joy from something that is supposed to add to our lives!!! Good luck xxx
  • Geraldine Watts Feb 11, 2008
    Hello wrong colours indicate printhead blockages, and mixed odd colours indicate colour bleeds, one colour not appearing indicates it has run out or blocked, but we have tried to correct your issue, so you may be the victim of a dud cartridge or it may just be time to replace it. You did not say if you buy new ones or refill yourself., it does happen sometimes (duds). I would remove it competely and try to just refill the yellow youself and if this fails, buy a new one, but make sure unit is completely clean before you replace it. Refill kits are available at pc stores and some supermarkets. cheers lilacgerry xxx
  • Geraldine Watts Feb 12, 2008
    Hello, i use the cleaning solution (pink) that came with my ink refill kit (lexmark compatable) I am sorry i do not know what type it is at is an unlabled bottle. Any correct cleaning fluid for printers is fine. Hot water is no good. I like to post to this site because it helps my nerve disease syringomyelia, and another undiagnosed one i have. It keeps my fingers and brain ticking over, so no worries. I have always loved helping people. Do not use hot water. Never put water anywhere near your printer either. When you used a new yellow cartridge and this still did not work, it tells me the problem is isolated to the yellow print head area where it contacts the printheads. Using proper printer cleaning solution, with a cotton tip, actually clean the little area where the cartridge goes in, not the cartridge. now replace yellow cartridge and try again. Does your printer have any other replaceable parts that you have to replace? Perhaps it is a driver error or system error. Did you try uninstalling the printer then reinstalling it if it is attatched to a pc. If it is a standalone unit, try turning it off, unplugging it, and turning it back on and trying again. Also, i have taken the liberty of submitting your exact issue to canons website and they will reply soon. I did not mention you do your own ink as they never like this! I do my ink and have no problems. It really does sound like the printhead in the yellow area is not picking up the ink at all, indicating a problem with just the yellow printer points. I hope this does not mean you need to take your printer to a repairer to replace the yellow printhead. I will post back soon when canon replies. Please tell me if your printer is attatched to a pc.
Exact same problem. Tried turpentine. It did not dissolve the ink completely. Water clearly doesnt work but i deduced the ink is coloured oil cuz soap seems to dissolve it a bit when i washed my hands.
ALso tried denatured spirit (ethanol) to no avail. Guess it is not covalent enough. Higher alcohols might be good. Im surprised turpentine dint work given that it is a paint thinner.
Posted on Nov 26, 2010
Hi guys
I have Epson R230 (Inkjet printer). Sometimes my some color doesn't work. All tanks full. Maybe this head problem or software problem. Some one tell me please. I hate Ink printers...
Thanks
Posted on Sep 02, 2008
Hi lilac!
hope u r fine. yes my printer is atached to a pc. thanks for forwarding my prob to the canon and also for keeping my little secret ;) the solution what u r giving me seems to give a kick but i guess i might not be doing it in a right way. apropos! i have come to learn that isoprophyl alcohol helps in unblocking the heads, is it right? if then what is it, an alcohol or a chemical?
should i go for it?
dear lilac, i will be going out of station tomorrow and will be back on 23rd feb, i can only fiddle with my printer on the 24th. meanwhile dont give up for me plleeaaaasssseeee. i will try to check my mails on the move but i doubt if i get a cybercafe where i am going. i will definately get in touch with u when i'm back. i dont know how this fixya.com system works but just in case then here is my mail add : islammohammed786@yahoo.com
islam.
Posted on Feb 12, 2008
Yellow not printing in Canon iP6600D printer
in the print out alone you can already know what print head is no working properly like missing color. if cleaning is not solving the issue this purging the print head. just read the user manual for the instruction
Apr 29, 2013 | Canon Pixma iP6600D InkJet Photo Printer
Epson Stylus Photo R800 not printing certain color
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 15, 2012 | Epson Stylus Photo R800 InkJet Printer
Yellow ink will not print
You may have blocked yellow print head nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
The Print head will contain all the nozzels for all the different colors so you cannot just replace a single color print head nozzels.
May 22, 2012 | Canon Office Equipment & Supplies
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
No shadow density in photograph printing
If you haven't been printing for 6 weeks, your print head is clogged, which is why the print quality is poor. Turn your printer on. On your computer, go to START, then SETTINGS, find PRINTERS AND FAXES and click on that. A window will open and you should see your printer. Right click on it, then click on PROPERTIES. A window will open, with several tabs. The one you need is MAINTENANCE. Open the tab and click on CLEAN PRINT HEAD. I think there are 2 options, cleaning and deep cleaning. Click on deep cleaning. You should hear the printer rumbling, then, when it finishes, it should print a page with 4 colors: black, cyan, magenta and yellow. If the colors come out right, you're done. If not, repeat the cleaning until you get a satisfying result. Just bear in mind that cleaning the print head uses a lot of your ink, so I suggest you put the refilled cartridges when performing this operation.
Also, to avoid getting in this situation again, I suggest that you print one page, at least once in 10 days. That way, your print head should always work fine.
If you found my answer helpful, please vote, it really means a lot to me to know weather I am helping someone or not.
Jan 13, 2009 | Epson Stylus Photo® RX620 InkJet Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Color Printing Problem
Remove all ink cartridges and replace them securely in position.That may be the problem always.
Print nozzle check pattern.See for any missing patterns
Give a head cleaning
Again print nozzle check pattern.If it is ok leave it, other wise give a deep cleaning
  1. If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
  2. Atleast a multi colour( like your visiting card) page should be printed in a week time. other wise the ink may clog in the head.
Mar 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
601 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
