Question about RCA HD52W59 HDTV Projection Television
Television malfunction I have a rca model f36668/y851 tv that quit working. When I turn it on I can hear what sounds like a relay in the right bottom of the rear of the tv that keeps clicking
  • RCA Master
  • 5,138 Answers
If you know how to solder - solder around Flyback transfomer,if not you need to order a deflection power supply board.this is where your problem is.ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 10, 2008
Rca p56830bl picture fade out
sounds like a vertical and horizontal deflection issue..maybe your control board is unhappy.
you inclined to do this work yourself?
Apr 28, 2008 | RCA P56830BL 56" Rear Projection...
Can't find a service manual for an RCA f36668
Send your email address to me by Fixya, and get back a copy of it by return mail.
Dec 27, 2012 | RCA F36668 36" TV
Rca Model number R52Wh73 Tv is not acting right
3 capacitors on your deflection board cp150 2200uf 16v cp114 cp120 220uf 35v
Dec 12, 2009 | RCA R52WH73 Projection Television
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
NO COLOR IN MY RCA F36668 TV
Could be a bad TV or it could be loose TV connections feeding to the back of the TV. Any poor or loose connections in the cable leads causes a loss of signal strength to the TV.
Old cables and connection supplying TV Cable to the house or apartment can cause this problem also.
Dec 05, 2008 | RCA F36668 36" TV
TV turns on & off by itself. Channels also change by themselves.
Make sure your remote is totally away from the set.
Make sure the buttons on the set are not sticky
If both of those are ok, it's your E-Prom in the set. RCA's are notorious for this, not a major repair, maybe $75-100. The 8 leg e-rom is only about $6.00
Apr 11, 2008 | RCA F36668 36" TV
RCA MODEL# F36668 TV, 36" OR 37"
If you feel comfortable taking the cover off the back, check the fuse that should be soldered into the board, near the power cable/etc.  If you do not feel comfortable doing that, then you should have a repair shop take a look at it.  It might be a cheaper fix than you think.
Oct 28, 2007 | RCA F36668 36" TV
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
No Volume Unless
you might want to take it in to a repair station. The buttons on the front might need replacing.
Jan 25, 2007 | RCA F36668 36" TV
RCA HD52W59 HDTV Projection Television Logo
76 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
