Question about Samsung SlimFit TX-S2783 TV
How to connect ps3
Pls help w/connecting ps3 to tx-s2783
  • 178 Answers
All you have to do is use the correct cables then select the video source on the remote or tv to the way you connected the cables.. Like if you connected the cable into video 1 select video1 on the tv.
Posted on Feb 10, 2008
Samsung TX-S2783 Deflection settings
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 29, 2016 | Samsung SlimFit TX-S2783 TV
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
I have an Onkyo TX-SR605 , I have my ps3 connected via hdmi and from the amp to a 3d tv via hdmi . when i am connecting through the amp the PS3 does not recognise i have a 3d TV and will not play 3d Movies...
No but you may be able to help me. I have the same amp and ps3. I have HDMI leads from both but cannot get sound or picture. I do get the set up menu which means it recognises the HDMI lead. How is yours set up ?
Jan 25, 2011 | Onkyo TX-SR605 Receiver
I have "Onkyo TX-SR304E" and PS3. Will this rcvr support PS3 in all means? Is there any special setting hat I ned to follow to get the best from my rcvr as well as PS3? Pls advise. Your help much...
what u can utilize on your tx-sr304 is the optical input at the back of the receiver. connect an optical cable from your PS3 into the receiver then follow these steps:
*make sure that the digital input on the front panel of your receiver matches where you placed the optical at the back of the tx-sr304 (either OPT1 or OPT2)
*all you have to do is keep pressing the digital input at the front panel until it goes to OPT1 or OPT2 (preferrably stay on DVD mode)
AFTER completing this go to your PS3 settings:
go to settings / then go to sound settings / then audio output settings / then set it to DIGITAL OUT (optical)/ then play and enjoy.....ü
Mar 05, 2009 | Onkyo TX-SR304 Receiver
Just wanted to know if my TV is HD or not. How can I tell. Model no. is TX-S2789 Samsung Dolby Digital
http://www.hdtv-source.com/reviews/B000F2R5I8_1.html if your tv is similar to this model then yes I assume it is HD.
Jan 11, 2009 | Samsung SlimFit TX-S2783 TV
ANTENNA TERMINALS
you need to take off the antenna so that can solder the antenna terminal inside the tuner.
Oct 02, 2008 | Samsung SlimFit TX-S2783 TV
How to connect dvd
if you use the standard red white and yellow connections from the back of your dvd player to the back of the tv on the in portion it will work. just make sure the tv source is selected as AV1
Apr 06, 2008 | Samsung SlimFit TX-S2783 TV
TV Blows internal fuse
You will have to find the source of a major short in your power supply.Since it's a 5A i assume i imagine that's where the short is.
Oct 23, 2007 | Samsung SlimFit TX-S2783 TV
Wierd sound when I switch on the TV
Your TV may something arcing inside of it. Maybe a loose connection. Since it is probably under warranty you should get in touch with the dealer where you purchased it. Perhaps you can get the whole TV replaced. Stargazer
Feb 20, 2007 | Samsung SlimFit TX-S2783 TV
Samsung SlimFit TX-S2783 TV Logo
94 people viewed this question
Henry  Thomas
Henry Thomas
