Question about Canon EOS-AE-1 35mm SLR Camera
Light meter problem and blank developed film
I just got a Canon AE-1 and its in good condition... but everytime I use the camera and push down the shutter button the light meter just keeps flashing at me and the little meter drops to the bottom... it doesnt change. theres a brand new battery in it and everything... and when i developed the film... it came out blank... i know i took shots and rewound it. but it was blank... help?
  • photolo Feb 11, 2008
    i put it on Automatic and the light meter is changing again and not blinking at me... i took 4 rolls of film... hopefully some came out? thanks though
    Problem Solver:
  • 18 Answers
I have thease cables and can replace it for you....send your camera to me and I will also clean it for you....total 75.00 Art www.flcamerarepair.com
Posted on Apr 13, 2008
  • 667 Answers
I'm afraid you have a somewhat serious problem. There is a tungsten cable that runs from the speed dial to the rewind side if the camera. This cable sets the brushes for the electrical contacts the are under the rewind assembly. Adjusting speeds or ASA changes the position of the contacts.
It is very likely that the cable has broken and needs replaced. Canon no longer supports these nor do they have parts
Posted on Feb 10, 2008
Why is my canon ae-1 only developing blank film
First thing I would do is sacrifice a roll of film. Load the film as you have been. Then with the back open and tension on the film (do not touch the film over the shutter, advance the film. It may be that you are putting the film on the takeup spool incorrectly. Watch how the film advances on the spool. If it is on the spool incorrectly it will disconnect then not advance. If that does not work it may be a errant takeup spool.
Jul 06, 2012 | Canon EOS-AE-1 35mm SLR Camera
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
Underexposure problem maybe? please help!
Your camera probably needs a new battery.
The light meter needs sufficient power (5.5v to 6v) to work correctly.
Your ISO could have moved, even a double or halving of it will over/underxpose a full stop.
Nov 10, 2009 | Canon EOS-AE-1 35mm SLR Camera
White streaks on photos
Light leak, definately a light leak. You need to change or add foam around the chamber to prevent any light from entering.
Jun 15, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AE-1 Dark Pictures
You my friend, need a user guide. Try this link:
http://www.lensinc.net/manuals/CanonAE-1user.pdf
Pages 23-26 will cover basic shooting. There is much to learn in the world of photography, so read the manual well and practice.
Dec 30, 2008 | Canon EOS-AE-1 35mm SLR Camera
Blank Film Developing
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Automatic aperture setting on canon FD lenses not working on AE-1
You have a case of AE(auto exposure) Unit faulty or getting bad. It suppose to register as it move within the AE unit according to the exposure calculation but somehow it is broken. Technician usualy replace the AE unit and takes care of the problem. It can also be rebuilt if new parts are not available. This requires complete disassembly and mirror box removal. The average cost of repair probably runs around $100. Yes, "A" mode is correct for most of the shots and it was a state of art electronic system and more computerized than you think. It has 3 IC chips in there for precessing and 1 chip for the exposure. All works together for good. -James
Nov 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Sep 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae-1
To open the back pull on the rewind knob ( pulling up ) until back opens. Check that your 6 volt battery is ok ( ae -1 has an electronic shutter so will not work without a battery ): battery situated on the left hand side of the camera ( if it is facing you ) underneath small flip up door ( lock is at the bottom on the left of the small door ) . Check the battery by pressing the shutter release gently and seeing if your light meter needle moves. No movement ? replace battery. You have two modes for taking pictures : auto which is actually AV ( aperture priority) or full manual : both are set by moving the shutter speed dial on the top right hand side ( underneath film winding lever ).
Sep 16, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
330 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
