Grundig tv set
Complete black out, no sound, no pictures. little burned smell from inside
Called a local mechanic and he fixed it. thkas.
Posted on Feb 12, 2008
    Problem Solver:
  • 5 Answers
Is there nay high voltage problem? which type of smell that was?
Posted on Feb 10, 2008
Grundig elegance 72 flat screen problem
sounds like frame collapse check out repair costs as can be rather expensive
Dec 01, 2012 | Grundig Televison & Video
I have no picture. Sound & Signal are working
It seems back light inverter board is not producing voltages to lit the back light inside lcd panel to show the picture on lcd screen.
Please replace back light inverter board to get tv fixed. Local tech will help you if you are not familiar with tv repair.
Thanks.
Apr 03, 2010 | LG 42LB4D 42 in. LCD HDTV
Can you plug a DVD player into a Grundig P37 - 1010(B)?
Yes, connection via Scart outlet at back of TV set. Just connected mine today, works perfectly.
Feb 22, 2010 | Grundig GF70-600 TV
My grundig lcd vision32lxw82-8510 has sound but no picture this problem is intermitant can you help? Thanks
If the screen goes completely black but still have sound then the backlight inverter board may be going out.
Oct 31, 2009 | Grundig 15 in. LCD TV/DVD Combo
No Power
Ok, easy !!!.( take it out the box ) Look, in the front part of the box TV ( under convergence panel controls) you will see a little black box, we call high voltages splitter ( 5 red wires go to pictures tubes and screen focus box). Replaced it. Am suggested inspected for possible leak coolant, just for be sure noy leak coolant projection and prevent future problems. I hope this help you, Thank you !!!
Aug 03, 2008 | RCA P52926 52" Rear Projection Television
Panasonic pt-47wx53 problem
What does the light on the front of the TV set do. This is a self diagnostic tool. How many times does it blink?
Aug 16, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Grundig Xentia - sound but no picture
in your tv is malfunctioning high voltage, the audio is generated without the help of high voltage sistem how happens commonly in many other tv
Aug 07, 2007 | Grundig GF70-600 TV
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
ProScan PS32500 32"-Picture has white static line & Static/burning smell
It sounds like the circuit board is arching over somewhere. It could be as simply as cleaning and digging out the carbon mark to stop the arching. This is most likely the screen or focus voltage causing this, if there are no parts that have broken down. This will damage the printed circuit board and make things worse the more you let this cook. This could be dangerous for you to mess with because of the high voltage present, so my best advise would be to get this into the repair shop as soon as possible before this board burns up. It should not cost all that much if the CRT board can be repaired. Good Luck
Mar 21, 2007 | Proscan PS32500 32" TV
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
