Question about Panasonic DMR-E80H DVD Recorder
DMR-E80H Component output
I don't get any signal out of the component output...I have to use s-video.
Is there something I have to set to get it to work?
I'm trying to hook it up to a Sharp AQUOS LC32D43U currently, but I had the same problem with my previous TV.
Any help would be sincerely appreciated.
  • richardbell Feb 10, 2008
    Yes, input source is selected and set to component.
  • richardbell Feb 11, 2008
    It's a standard set of red, blue, green coded component cables connected from the component outs on the DMR-E80H to the component inputs on the Sharp according to the colors on the plugs. I did a firmware upgrade on the DMR-E80H a few years ago, none recently.
  • 178 Answers
Are you selecting the right video source on your Tvs? please ket me know or you can call.
Posted on Feb 10, 2008
  • Jason Medeiros
    Jason Medeiros Feb 10, 2008
    Ok how are you wires connected. Which ones are you using? Also have you done the firmware upgrade on this unit? Please le me know.
My Panasonic DMR-EH55 has suddenly stopped outputting. Regardless of whether I am using the HDMI or component outputs, my Sony tv indicates "no signal". What kind of problem am I looking at?
Try it with another TV, perhaps a friend's or neighbour's. If the problem persists, consult your local Pana service centre or a competent technician
Sep 25, 2013 | Panasonic DMR-EH55 DVD Recorder/HDD...
I have an older 2004 or so philips hdtv projection tv with the built in tv stand. i want to connect my HD cable box but there are no hdmi ports. and i buy a wire with the VGA on one end and hdmi on the...
Get a component video cable (blue, green, red) and a separate RCA audio cable (white and red) if your cable box has a component video output and the TV has a component video input.
If your cable box doesn't have the component output, you will need a converter to go from the HDMI to component video. Something like this: http://www.hdtvsupply.com/hdmi-to-component.html . There are other converters available if your TV has some other inputs available.
A cable that has an HDMI M on one end and a VGA M on the other will not work. HDMI signals from the set top box are a digital signal. The VGA port on the TV is set to read an RGB analog signal. (Similarly a component to VGA cable would not work since the RGB and PbPrY are not compatible.)
I hope this helps.
Sep 02, 2011 | Philips 60PP9363 60" Rear Projection...
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to transfer Panasonic DMR-E80H recorded DVDs to computer
I have to agree with XELIAM regarding finishing the disk, under the DVD "FUNCTIONS" selection from the remote. I also use the SLYSOFT products to transfer my videos to what ever other mode of video I wish to have, whether iPOD (MP4), or DIVX (AVI) or loads of other options. Slysoft makes a GREAT product
Dec 04, 2009 | Panasonic DMR-E80H DVD Recorder
My DMR-E80H will no longer record onto blank DVDs
One solution is to clean the laser lens. Try using one of those lens cleaning CDs.
Also, sometimes the DVD may slip on the spindle, which may cause reading errors. Spindle cleaning usually involves taking the machine apart.
Oct 04, 2009 | Panasonic DMR-E80H DVD Recorder
Panasonic DMR-HS2 RF out is not outputting signal CH3 CH4 off
The most likely cause of this is the unit being in progressive scan mode. In progressive mode, the composite output is disabled. If you can, connect the DVD using the component output connections. If your TV does not have component input, connect the green connector to the yellow on the TV. If the unit is in porgressive scan, you will see a garbled picture on the screen. The only way to fix this is to turn off progressive scan. The manual will tell you how to do this.
Dan
Apr 10, 2009 | Sony STR-DG510 Receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
Picture from analog tv signal is not sharp
I have this same machine, you did'nt mention what input you are using (composite, S-Video, component or HDMI) or what type of display you have (CRT, LCD, Plasma etc.).
If your T.V. has a HDMI input I recommend using that, if not and it's of fairly recent vintage use the component inputs (not to be confused with composite video inputs, or yellow RCA-type input).or at the very least use the S-Video input.
In the setup menu (on screen) try setting the "TV Screen" option to the 480p setting and if you are using the HDMI input try setting that to the highest resolution your T.V. has or set it to "Auto"
Finally in the on screen video menu select the "Video" setting and set the "Still Mode" option to automatic, and the "Output Level" to lighter or darker whatever your preference is.
Remember...Always use HDMI or component video inputs on your television (if it has those inputs)!
Hope this helps!
Joe
Nov 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR E80H Video recorder remote
While pressing [ENTER] on the remote control press the [1] button on the remote - that should change the remote's control code back to one.
Jul 28, 2008 | Panasonic DMR-E80H DVD Recorder
Fuzzy Picture
Are you using the component (RGB) outputs, and a Sony TV? I believe that there is something in the output of at least some Panny DVD recorders (over the RGB component path), which Sony TVs don't process properly.
Aug 15, 2007 | Panasonic DMR-EZ17 DVD Recorder
Panasonic DMR-E80H DVD Recorder Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
