Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
During XP installlation
When i was installing windows XP after doing format throught NTFS the windows copying the files,At that moment it was stuck and sad press enter to continue or press F3 for skip the file.i tried both options but i can't succeed.
plz help me.
    Sniper:
  • 66 Answers
Hi proably a bad cd u have is it a original xp?
Posted on Feb 10, 2008
Format windows 7 and install windows xp
Use the XP install disk to format the drive during the install process with NTFS file system. Then install XP.
If the disk does not allow you to go backwards to an older OS you need to format the existing drive in your laptop with external software on a usb or cd rom, etc. Then do the xp install. Before doing the deed make sure you download the drivers needed for the XP install on a usb stick or something.
Feb 12, 2016 | Computers & Internet
My laptop lenovo ideapad y450 shows blue screen error.i tried to format with windows xp also,but it appears once format was completed also.advice me pls
Dear! Delete your C drive and create again with the help of windows and then format and install Windows. Your problem will be fixed.
Jul 27, 2011 | Computers & Internet
Xp is not install
Best solution is to get and use the original restore discs.
If using a regular XP disc installation requires specific technical steps to boot from the disc , delete the existing partitions, format and install then download original drivers one at a time.
Getting the original restore discs would be alot easier than using an XP disc
hope this helps
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Apr 03, 2010 | Computers & Internet
I want convert ntfs to fat 32
the convertion from ntfs to fat32 will result in loss of all data in the drive (all data from desktop,my documents, installed programmes.......). You can do this using your windows disc . Just set the primary boot device to be cd-rom in the bios,boot with windows cd in drive,then the installation will guide you to the insallation of a fresh copy of windows (there you can select the required file system).it is recomended to continue with ntfs
Feb 28, 2009 | Microsoft MS Windows XP Professional SP2
RAW file system
RAW file system is typical of an unformatted hard drive and is the default state for most new retail drives because the manufacturers won't know which operating system their customers are going to put on the drive or use it in conjunction with.
Most operating system installations come with utilities to partion and and format new drives see fdisk from MSDOS (specifically versions 5 and higher) And MS Windows 3.1 through 95,98 and ME which all used the FAT32 file system as default and would partition and format during installation. Windows NT similarly would partition and format the drive during install to the NTFS system, as do all versions of Windows XP.
if you are not installing a new OS but setting the drive as a slave to a currently installed drive then you can use a program like Partition Magic or similar to detect the installed drive and partition / format it tou your requirements
Oct 08, 2008 | Computers & Internet
Win xp clean installation problem
This sounds like a bad sector in the hard drive. Did you do the full NTFS format or the quick format? Big difference. The full format should pick up on the bad sector and won't be able to format the drive. Run a full format and let ke know what happens.
Aug 29, 2008 | Intel Motherboard
Auto format new hard drive in new custom pc
If you mean boot from cd with xp pro during setup you will have the opportunity to format drive either fat32 or ntfs use ntfs
I have never done it but if you can do it partition your hard drive so that you can save personal file and programs on second partition then if you have to format drive again your files on second partition will not be lost
Aug 04, 2008 | PC Chips (M925G) Motherboard
How to re-format my Maxtor drive? My OS is Windows XP - SP2
Boot to the XP CD, during the XP Setup, you'll have the option to reformat the drive, and the choices of NTFS or FAT32 File system
Jun 05, 2008 | Computers & Internet
Drivers required
SCSI Drivers are only an optional part.
This is not a problem with your driver floppies.
The problem is with the linux being preinstalled on the HD.
Linux uses many types of file-systems. Even if it was NTFS or FAT, it is most probable that windows xp cd won't be able to recognize it; because, it may use unsupported method of formatting.
What you have to do is;
1. Format the two HDs by either
  • Moving it to another windows or linux computer and fully formatting the Hard Disks using fat32 or NTFS (supported by windows). If it is a windows PC using for formatting, no problems. If it is a linux system, delete all partitions, and format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
  • By a linux installation CD and here too, format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
2. Install the windows xp in it, using the same booting from CD Porcess. Here, you may or may not choose to install the SCSI drivers ( the floppy you got by pressing F2 when it says to do so in the installation immediately). It is good not to install the SCSI drivers if it is not a necessity for you.
Now, you can create any number of partition, format, etc during win XP installation.
Feb 18, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
