Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
No input signal hdmi
Hooking up the ps3, hdmi. worked one minute but now keeps reporting "no input signal" connections are all good. with this?
  • pbangout456 Jun 22, 2008
    same problem with the ps3 it was hooked up before, but no signal hdmi cable or regular hook up without hdmi cable, cant figure out why. i hooked my ps2 up right after and it worked fine, but ps2 does not have hdmi, please let me know
  • 178 Answers
Are you on the correct video source on the TV
Posted on Feb 10, 2008
No signal input ps3
Try that PS3 on another TV or monitor with an HDMI input to check the PS3 is working ok. If it is try a different HDMI cable.
Dec 16, 2013 | Panasonic VIERA Televison & Video
How to connect to HDMI
newer tvs need to know that HDMI is attached to give you signal also need to turn on device from where HDMI signal comes from.post the model of your tv ,or if universal remote has input try this,1.- connect hdmi ,2.- turn on device(dvd,ps3,blue ray, etc.) 3.- press input on remote ,or go to menu manually on tv and find input.hope it works.
Dec 14, 2013 | Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Hook up ps3 and appletv to my tv - i have a Sony receiver w/HDMI slots that i am using for the PS3 - i have hooked up the Appletv to the HDMI input 2 on the back of the TV. The PS3 will not show video - i...
There are generally three HDMI slots at the back panel of an HD TV. Make sure you have connected the PS3 and the Apple TV in two separate slots. Sound will work because you must have hooked it up in Audio IN at the back or if you have connected the red and white audio cables in the front panel , the audio will work only on the camera setting on your TV
Feb 06, 2011 | Hitachi 50VS810 50" Rear Projection HDTV
My tv is not picking up any hdmi signals from my ps3 and xbox. whats wrong?
The first step for this issue is to try a hard reset. Hook up the PS3 with both the Analog cable and the HDMI, set the TV to the Composite (analog) Input that you have chosen. Then, while the PS3 is off (red light), press and hold your finger on the power button for approx. 10-15 seconds until it beeps again. This will reset the PS3. After it turns back on, go through the set up steps, and after, it may tell you it has detected an HDMI connection, say yes and switch the TV to the HDMI input you hooked it up to. Click on yes before the timer ends and you should be all good.
Jan 21, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have a Playstation 3/blu ray player and I don't know how to get hi def video on a samsung hln467w
Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
464 people viewed this question
Top Digital Lifestyle Televison & Video Experts
CoppellTVRepair.com
paul
paul
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
