Question about IBM ThinkPad T22 2647 Notebook
My T22 unable to start
Hi all,
My T22 cannot not start. When I connect the AC cord to the laptop, the battery lamp turns green. I then press the POWER ON button, both the HDD lamp and battery lamp flash for less than 1 second (none of the other lamps flash), then only the battery lamp remain green.
Any expert can advise me what is the case? Thanks very much.
Yamato
  • bbyamato Feb 10, 2008
    Hi Benimur,
    Thanks for your advice.
    I tried option 2 first with the battery removed away.
    At first, no response at all. After detaching the battery for about 5 hours with the laptop OFF, I tried again. This time all the following lamps turned green for less than 1 second : NumLock, CapLock, Scroll Lock & PowerON. Then, only the PowerON green light remained.
    I will try to detach the battery away with the laptop OFF for 12 hours first to see if there is any improvement. If not, I will try option 1.
    Yamato
  • bbyamato Feb 20, 2008
    Hi again Benimur,
    The adapter/charger is the original one.
    Finally, I have tried to detach the battery away with the laptop OFF for 24 hours and the laptop can be ON and work properly (only have adaptor connected without the battery). I am now working on file recovery and backup.
    By the way, thanks very much for your kind help.
A good read ! http://www.batteryfast.com/
Posted on Jun 10, 2008
    Brigadier General:
  • 6,966 Answers
Hi Yamato,
It is possible that the battery has been so depleted that it gobbles up all the power from the charger/adapter and leaves nothing for the laptop to use. Perhaps what you can do are:
1. try and charge the battery at least overnight with the laptop off;
2. use the adapter/charger only and remove the battery from the laptop.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 10, 2008
  • Louie  Role
    Louie Role Feb 10, 2008
    Hi again Yamato,
    May I ask, is the the adapter/charger the original one or is it a replacement pls?
When i turn on, the green light comes on then goes out,why
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 28, 2012 | Computers & Internet
Hi, My laptop, Compaq NX7010, does not start when pressing the start button. Nothing happens. There are no extra equipment connected, and this happen with or without the power connected. Battery is...
The RAM module may be faulty or just need reseating to make proper connection.
Try reseating the RAM modele/s and if this does not work then remove the RAM module/s and take them to your friendly computer repair shop and get them to test your RAM.
Jun 13, 2011 | Computers & Internet
My laptop wont turn on and yet its fully charge. The power light keeps on blinking with orange and when i push the start button, it turns green and when i stop pushing, it turns orange again-blinking.
Hi.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Regards.
Jun 08, 2011 | Sony Computers & Internet
Hi i am using dell latitude d600 problem with charging the battery 3 or 4 time orange light flash n 1 time green light . im unable to use my laptop with battery it working well with A.C power
Try to perform power drain. Take out the battery unplug the power adapter then press and hold the power button for 30secs. Put the battery back in then plugin in the power adapter then turn on the computer. If same issue occur, then you need to replace your battery.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 18, 2010 | Dell Latitude D600 Notebook
Toshiba Satellite A15-S127 won't power up
basically this may be the fault of ram or ram slot connectivity problem.
Aug 23, 2009 | Toshiba Satellite A15-S127 Notebook
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
AC wire connection may have problem
try this remove the battery and plug it in to the power supply and turn it on if everything works fine its the battery if not its the charger which you'll need a new one
Jul 30, 2008 | Toshiba Satellite A70 Notebook
IBM ThinkPad T22 2647 Notebook Logo
134 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
