Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
Picture the picture on my tv screen don't go to the top now. It's more then half way of the screen but has black then the picture
  • ladyde Feb 17, 2008
    Hello Andy thanks for your reply but I think I clicked on the wrong model my model # is GB5108 made in april 2002. but you are right it is a vertical problem and do you have this model part in stock and if so how much and is this something I can put in myself.
  • 48 Answers
Sounds like you're having vertical problems. I saw the vertical chip on this set go bad several times. Location is CN301. Sometimes you may see a big dent or even a hole in it. If that is the case, you need to replace it and check around it for any blown parts or loose solder joints. If you don't do that, the new chip will be destroyed. I have it in stock if you want it.
Posted on Feb 13, 2008
  • Tony Harrison Feb 17, 2008
    Hi- I'm pretty sure this model also uses the same vertical output chip as the GB4308. Can you do it ? Frankly this is hard to say. You need to be able to work very carefully and to take the board out, or at least partially to get to the bottom of the main pcb to do some soldering / unsoldering. I don't know anything about your abilities. It is fairly easy to replace the chip but you have to be able to check for loose connections around it and also all the electrolytic capacitors in the vertical area. If you had done electronics work before, I'd say go for it. But if you never touched a soldering iron before, it could be tough for you - especially since any slip or wrong move can make things much worse. Sorry, but I'm trying to be honest with you. I can sell you the chip $12.99 shipped. Thanks.
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
I have a 22 inch AOC Envision LCD TV. When I first turn it on, only the top half of the screen displays picture while the bottom half is a gray/black color. If I wait about ten minutes or if I tap on the...
There is some loose solder terminals at the vertical scan output section at printed circuit board. If you are handy in electronic circuit boards, loacate the vertical output section, resolder all the suspected solder terminals there. This must surely rectify the problem to your TV.
May 18, 2012 | Televison & Video
Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Jul 31, 2010 | Toshiba 32AV502R LCD TV
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Apr 09, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Screen was going red on the top half of the screen, then..
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
Jul 23, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
May 21, 2009 | HP PL4260N 42 in. Plasma HDTV
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Half a picture in black
Witch part of the screen you loose?if is the bottom or the top it could be a problem in the vertical IC circuit if is the left side or the right side is a problem on the horizontal deflection circuit(very rare),try taping on the set when it does it and see if the pix reacts ,if it does one way or the other you have loose conections and some resoldering need to be done.If you are familiar with tv circuitry you will have no problem.If you are not be safe and call for help.
Sep 19, 2006 | Mitsubishi (WB2000)
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
47 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
