Question about Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV
Pioneer pro 506 pu 3 lights stuck on
My tv suddenly shut off while playing my ps3. according to the owners manual it said the tv overheated? and there were internal circuits. so i looking inside the box and saw nothing resetable. i seen a fuse which seemd fine . i hooked it back up now all 3 lights are stuck on. ( befor just the standy was blinking) i unpluged it all . checked my wiring . id like to know how to rest the tv or if there is any thing i can do i need help asap( the screen will not power on so i cant look at any options)
  • 2 more comments
  • ryne88 Feb 11, 2008
    well at first when it shut down just the red lights were blinking . which is the standy lights. when i hit the power button it attempted to turn back on then shut down. (stayed on about 2 seconds). then i took the cover off the media box. because my house is on a main streer in chicago which generates alot of dust. so i blew into the box to remove some dust( note the box has some kind of switch inside the box that i suppose is to know when the cover has been removed. like a dryer door switch) then i put the cover back on and tried it again. now the blue power light stays on red standby light stays on and orage rec timer light stays on. and the media box is non responsive what so ever. for example if you press the power button it neither turns on or off. the only way it turns off is to unplug it . normally when it turns off you here a click. when its upluged you dont here that click now and the lights stay on for about 10 seconds befor they loose power. have i anwsered your questions?
    that anwserd the second part of my problem . yet that wasnt the inital problem as i stated earlier . do you know what may have caused it to cut off initally? (red stand by light blinking befor i took it apart) thanks for your input c dog
  • tomybear Feb 18, 2008
    After watching my Pioneer PDP-4340HD TV for about three hours, the TV shuts itself off. I can use the report to power it back on and continue watching immediately but this continues to happen night after night. When it first turns back on, the timer record light blinks about thirty times before going out.
  • Carl Manaloto
    Carl Manaloto May 11, 2010
    First tell me about the blinking lights in as much detail as possible. which ones are blinking what colors are they?
    C-Dog
The service man said that there must have been a power line voltage drop that causes the TV to shut off but I don't think this is happening night after night.
Posted on Feb 18, 2008
  • 84 Answers
You activated the trap switch. You must now call an authorized Pioneer service center near you. They are the only people that know how to deactivate it.
C-Dog
Posted on Feb 11, 2008
  • Carl Manaloto
    Carl Manaloto Feb 11, 2008
    That's just it, you won't know how many times the red light was blinking for the error code unless you get the trap switch deactivated. But an authorized Pioneer service center will know all that info.
    C-Dog
Hi. My PS3 suddenly started turning off randomly in the middle of play (grrrrrrr) but I know its not overheating since the red light didn't flash and there was beeping. It just died. No joke. Does anyone...
There could be an issue with the power cord or the power outlet.
Try to get a replacement cord and plug the PS3 into another outlet. Turn on the PS3, and let it sit on the menu screen for a while. If it does not shut down it means that it was a power issue.
Mar 07, 2011 | Sony Playstation 3 (PS3) Console
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
I was playing Modern Warfare 2 when suddenly the PS switched itself off and won't come back on, the disk is stuck inside it.
If the unit is blinking a red light when it turns off this is known as they yellow light of death for the ps3(ironic i know). This can be caused by the unit overheating causing solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
Ps3 will not turn on......yellow indicator light only was playing game and suddenly the system just shut down and only a yellow line appears and ps3 will not turn on
This is coused by overheating of the console, make shure that
the hot air from in the console can get away and the console
stands completely free so that fresh air can reach the console.
Jan 05, 2010 | Sony Playstation 3 (PS3) Console
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
HELLO. I was playing on my ps3 When suddenly it just turned it's self off in the middle of playing tekken 5 DR oline. Now when i turn my ps3 3 on it just's beep's and turn's tisefe off.....HELP ME PLEASE....
Your PS3 probably overheated during game play.
No it's stuck in the "off" position.
There's isn't much you can do besides trying to reset the video.
While the PS3 is off (red led)
Hold down the power until you hear the second beep, quickly release.
Hopefully you're one of the lucky ones.
If not you need to contact Sony @ 1-800-345-SONY
for repair.
It's more than likely a motherboard issue.
Best of luck!
Jun 15, 2009 | Sony Playstation 3 (PS3) Console
TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Jan 28, 2009 | Pioneer Elite PRO-111FD 50 in. Plasma TV
PS3 wont work
How long were you playing it? if you were playing for a couple of hours, then it could of just overheated, in which case the ps3 will shut itself off suddenly to keep from damaging something. It should work after about half an hour, adequate time for it to cool down, if not, then you might of damaged something.
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV Logo
880 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
