Question about Dell Inspiron 9200 Notebook
Display not working
At power on the Display may flash for a second, then blank. I can hook up an external monitor and it works what are the most likely problems to look for or replace?
    Genius:
  • 3,587 Answers
Motherboard is what we usually recommend on field replacement. Might be the LCD too. You under warranty? Got Backup?
Posted on Feb 10, 2008
Will not turn on,
Try these.
- Remove battery, press power button for at least 20 seconds. Power on the system using the AC adapter (charger).
- Use another working AC adapter if still no power.
- Make sure that the DC input jack where the AC adapter is inserted to the laptop is not broken, otherwise, replace motherboard.
- If you get power but blank screen, connect an external monitor. If you get display on the external monitor, the LCD needs to be replaced.
- If you get no display on the external monitor, reinsert the memory module/s (RAM), otherwise, the motherboard needs to be replaced.
Hope this helps.
Jul 17, 2011 | Toshiba Satellite L455DS5976 Notebook
Hi there i have a sony viao laptop pcg-7121m, there is no power to the display so when i switch on the laptop the power button lights up but there the screen stays blank, how can i try and trace back the...
Try holding down the function button on the keyboard and tap the F key with the (O) symbol above it, Its the symbol for monitor. You may have to press them a few times. That will toggle computer from its external only monitor mode. If not then hook up an external monitor to the computers vga jack and try again. If you get the external monitor to work that way and not the built on display then the built on display will need replacing and if it does not go to working at all then its most likely a motherboard issue. If the external display does work then you can continue to use it that way until you get the screen repaired/replaced.
Aug 25, 2010 | Computers & Internet
The computer boots but there's no display
check the display properties for dual monitor settings in
display properties>settings> check all options
I think it is set for external display u change to dual display. then both displays can work. or there is some display symbol of some function key. check that and press
Jun 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Hp L1502 LCD blank, LED still flashes
just check ur lcd display cable and try to clean and c it it will cme
May 29, 2009 | Samsung SyncMaster 910T 19" LCD Monitor
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Dell Inspiron 9200 Notebook Logo
Alun Cox
