Question about Mitsubishi VS-60607 TV
Dark Screen and red and blue lines
When my tv is first turned on the screen is dark and there is a red and blue line in the first inch or so at the top of the screen. After a while the darkness seams to go away but the lines are starting to stay but appear to be in a very gradual arc at the top. The set is from the year 2000 and has never had any problems or any work at all done on it. Thanks
  • dura_cell Feb 10, 2008
    Would the leaky capacitor be in addition to the bulb from the darkness or could that be causing that also? In addition, what is a appropriate charge for the repair.
    Sergeant:
  • 395 Answers
Dark unstable picture
1. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND CHECK IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. you may also have a convergance problem. failure of convergance amps cause the arch at the top. the picture will look slightly out of focus. the cost of your repair may be $300.00 to $375.00
Posted on Feb 10, 2008
  • 68 Answers
Those lines tell me that you may have a leaky electrolytic capacitor in your vertical circuit.
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Nov 13, 2008 | Televison & Video
Dark screen red arched lines
turn down the red screen control slightly the box is located behind the grille 6 knobs on it look carefully for the screen making on it for red do not adjust any other control best done in a dark room with no source in a video input if the tv will not auto align you have the control backed off to far
Oct 06, 2008 | Sony KP-46WT500 46" Rear Projection...
Screen slowly turns blue...
I had blue lines showing up on my screen, then the other night my screen started to flutter the blue, bright to dim and back. So I followed this link to resolve the blue lines and the blue flutter was resolved as well. Hope this helps.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jul 26, 2008 | Sony KP-51WS500 51" Rear Projection...
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi rear projection tv white screen goes dark and....
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Blue and red arched lines on screen when background dark
Sounds like you are describing retrace lines that could indicate that your CRTs or something in the drive circuits are bad.. Check the resistors on the CRT sockets to see if they are in tolerance. If they are try turning the red and blue screen adjustments down just a little this should take the lines away. You will however be needing service in the not to far future. Turning the screens down should help if the resistors check out. Let me know if you need anything further.
Jan 31, 2008 | Sony KP-48S35 48" Rear Projection...
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Mitsubishi VS-60607 TV Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
