Question about Motorola Mobility RAZR V3i Cellular Phone
Missing file i connect my phone to my computer and i install some program on it after that the phone went turn off and turn on i went to workshop and he format my phone and installed again now my phone show one file missing. What is the problem please help me
    Sergeant:
    Champion:
  • 281 Answers
You need a program that is called: Files Back up
Using this program it will help you get your lost files
Posted on Feb 10, 2008
Lenovo a516 phone cannot transfer and received files from acer netbook
Without the proper drivers, a connection will not be achieved. Did you install the communication drivers? Your computer may show you that a Bluetooth device is present, but without communication drivers, you just have dead space.
Jan 03, 2014 | Lenovo 3000 Y410 Notebook
Deleted all my songs from phone
Download a file recovery software and install into a computer. install the exe file and run program, then connect your phone in to the computer and select masstoreage mode. go to the program and select the phone storage and you will get your old files.try it .remember it's a slow process.
Aug 12, 2012 | Pantech Impact P7000 Cell Phone
Purchased a USB cord to download photos from my phone. Can I use it without having a disk to install it into my computer?
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease Save PC Suite to Program Files on your computer. You need this software before you will be able to connect with your phone. (2nd) after you download this software you need to go to and open the Program Files folder on your computer. Then open the Pantech folder. Next open the Pantech PC Suite folder. Now open the P2020 folder. Finally open the USBDriver folder. This folder should contain some that looks like PTQH_V1_1_4583_1215_SETUP Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this helps
Dec 08, 2011 | Pantech Cell Phones
Hpzprl01.exe missing during installation.
1) Run the driver installation normally and let the error occurs;
2) Connected the Printer to USB;
3) Turned on the Printer;
4) Windows XP recognize the Printer and open the Installation Procedure;
5) Change to find the install programs manually;
6) Find the file C:/Temp/HP_WebRelease/;
7) The installation perform almost good until ask for file hlpmom12.dll, if you are using language different than English, in my case I was using Brazilian Portuguese;
8) Open the Explorer and find the missing file inside C:/Temp/HP_Release/;
9) Inform the full path for the missing hlpmom12.dll;
10) Then the installation completes successfully.
Aug 10, 2010 | Computers & Internet
How to put a application to a samsung sgh -d900i
first you need to download 3 programs & then use from them.
1.JADMAKER for make jad files from jar aplication files.
u can download it here :
http://www.softpedia.com/progDownload/JADMaker-Download-8344.html
2.u must dowmload an uploader software foruploading jad file to ur phone
(its easy to find by searching in google)
3.u need to softicppp software too!
follow this path :
install all programs
Load Softick PPP gate and click cancel on the missing USB file prompt as it is not relevant for this activity.
Type in from the standby screen of your phone; *#52828378# and select OTA type setting as Serial OTA bearer.
From there, go down to Serial test and choose PPP up
From the computer, go to usb and double click on the serial port.
Back on your phone,select usb,you will be loading your files with a usb connection.You will have returned to the serial test menu if all has been done right.On the computer, load Samsung XXXX uploader and load a .jar file .On your phone, you now need to push Serial Download.If your phone has not crashed, you should see a dartboard, the java logo and a small progress bar.The game will automatically start downloading.When the game has been downloaded, it will start automatically.Make sure you turn off PPP from Softic as the phone is restarting. Once the phone has restated, activate PPP again and press Yes on prompts to serial connect and try again.If it keeps crashing, try re-reading the instructions. Or your phone is not compatible with the game.
Sep 25, 2009 | Samsung D900i Cell Phone
Connect HP 3015 all in one printer to Aspire One
Disconnect the printer from your computer. Go to Start -> Control Panel -> Printers. Right-click on the HP 3015 printer and select Delete. Confirm the deletion of the printer. If it asks about removing unused driver files, answer Yes. Reinstall the driver files using the provided setup program. Do NOT use the Add printer... dialogs. If the installation program prompts you to plug in and turn on the printer then do so, but do not do this before it prompts you. This is what generally causes the missing files problem. If it goes completely through the installation without telling you to plug in the printer (which would be unusual for HP printers), plug it in when it completes. It should automatically recognize the printer being plugged in (and turned on, if necessary) and then finalize the driver configuration.
Mar 18, 2009 | Acer Aspire One PC Notebook
Unable to install a game onto my computer
in your system their is some files missing! so for that you have that problem! please install correct OS to your computer!
Jun 19, 2008 | Nokia 1110i Cellular Phone
Error message
Dear riajane
Uninstall the workshop 2008 and reinstall it. If it is not passable remove the manually in program folder as will as registry be careful wheal removing in registry. And reinstall it
Feb 03, 2008 | Computers & Internet
Microsoft Visual C++ Runtime Library
just fully uninstall your pc suite from your computer restart it then install it again, normally it happens beacause of any single file is missing there unexpected way. after installing connect your phone.
Dec 23, 2006 | Nokia 6670 Handheld
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
