Question about Konica Minolta Dimage Scan Dual IV Film Scanner
DS_Dual4easy software for VISTA operating system?
Are there drivers for a DiAmage ScanDual IV scanner?
  • 2 more comments
  • KoenV Mar 27, 2008
    same problem here, will keep old pc for scanning now
  • Detachsoon Jul 28, 2008
    is there a driver for the Dimage Scan Dual4 Scanner that will work on the Vista operating system?
  • Anonymous Sep 09, 2008
    Need driver for vista.
    MK
  • amartin621 Mar 23, 2009
    scanner software worked fine with XP but just got new computer with Vista and it will not work. I have tousands of slides to scan. Can anyone help?
  • 14 Answers
1) Install the Konica Minolta XP software in Vista/Windows 7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It will detect and install the original Konica Minolta Driver.
3) Create an empty folder on you harddrive (for instance go to my computer, double click on the c: drive, then right click and create a new folder named newminolta).
4) Open windows notepad and copy the following into it:
; scanners.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USBVid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USBVid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USBVid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USBVid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USBVid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USBVid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USBVid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USBVid_0638&Pid_0a16
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c: newminolta newminolta.inf)
6. Go to system control panel (may have to change control panel to classic view to see system).
7. Select Device Manager
8. Select Imaging Devices
9. Right click on Minolta Scan Dual IV and click on driver tab. Select Update Driver.
10. Select Browse my computer for driver software.
11. Select Let me pick from a list of device drivers on my computer.
12. Select Have Disk
13. Browse to c: newminolta newminolta.inf and click OK
14. Click Next. Vista should now say it updated driver.
15. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
16. Open door and insert film holder and start scanning.
Posted on Dec 22, 2009
Scanner shut down improperly and will not reboot because message says check Confirm all other Dimage Software is closed. I have done everything I can think of including reinstalling software and removing...
Please restart PC.
If it cannot be started up after restarting PC, delete two files shown below:
/Library/Application Support/DS Elite5400 2/MFSLibInit
/Library/Application Support/DS Elite5400 2/MFSButtonCheck
/System/Application Support/DS Elite5400 2/MFSLibInit
/System/Application Support/DS Elite5400 2/MFSButtonCheck
Jan 10, 2011 | Konica Minolta Dimage Scan Dual IV Film...
Hp scanjet 2400 - system is format but Scanner CD is missing how to install scaner software
Just goto th hp site and enter the model of you scanner, download the drivers. Don't forget to select your systems operating system (XP, VISTA)
Thanks
May 15, 2010 | HP ScanJet 2400 Flatbed Scanner
My new computer will not display the scan window
Did you install the scanner latest driver for your Operating system?
if not, go to the scanner manufacture's website to download it
it should be in the support tab
Good luck
Jun 17, 2009 | Nikon Coolscan IV ED Film Scanner
Installation
I had the same problem with my Coolscan IV. The problem ended up being the scanner, which had several broken pieces in it when it arrived. Since the Nikon repair facility in Las Angles wanted $200 plus parts to look at it and repair it, I subsequently purchased a Coolscan V and went to the Nikon site and downloaded their latest drivers (ns403en_vista.exe) - which worked (works) fine and does a beautiful job. If you follow this route, make sure that you download the correct version, i.e., the Vista version. I have been able to make the scanner work well using both the XP and the Vista Nikon drivers, since I have both an older XP desktop and a new Vista Laptop. Good Luck.
May 27, 2008 | Nikon Coolscan IV ED Film Scanner
Windows vista says no to oldschool
After Vista servicepack1, your HP4200C Scanjet should work if you use the latest drivers from sj655en.exe downloaded from HP.com.
May 12, 2008 | HP Scanjet 4200c Flatbed Scanner
Vista Cannot Locate Scanner Driver
windows vista has compatibility problems with many device softwares and drivers, u have to get the software that's windows vista compatible, or u can log onto the visioneer site http://www.visioneer.com/ and download your device's software that's compatible with windows vista
Feb 02, 2008 | Microsoft Windows Vista Ultimate Edition
Driver's software installation problem
is it vista ready drivers if not u need to go to website get new ones
Feb 01, 2008 | Microsoft Windows Vista Ultimate Edition
Minolta DiMage Scan Dual IV
1) Install all of the usual Minolta software in Vista.
2) Create a new folder somewhere
3) Create a new txt file named minolta.inf and paste this into it:
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. All the normal Minolta programs now work just fine. Enjoy!
Jan 27, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Konica Minolta Dimage Dual IV
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c: ewminolta ewminolta.inf)
13. Browse to c: ewminolta ewminolta.inf and click OK
Jan 12, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Dimage Scan Dual IV worked fine when I first got it then I put tiger on my mac and when I click the the launcher I get the following error messge: "a shared libary error. 4
Do you have a file called MFSButton Check sitting on the system - if so, delete it. If that doesn't work then Try uninstalling the Minolta software from the computer and then reinstall the software. This should reset how the OS and the scanner talk to each other
Sep 28, 2007 | Konica Minolta Dimage Scan Dual IV Film...
Konica Minolta Dimage Scan Dual IV Film Scanner Logo
601 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
