Question about Rowenta Steam 'n Press DA75 Iron
Rowenta DA75 - Won't Steam
I fill the tank with distilled water, set to steam, press the steam button at last time 32 times & no steam came out. The iron/steamer gets hot & irons but won't steam.
  • 11 more comments
  • jackie green Dec 29, 2008
    How do I fill the tank, I found one at a sale and it didn't come with instructions.
    I need help with a steamer, How do I fill it with water and should it be distilled water.
  • petaldaisy Jun 01, 2010
    I have no manual for Rowenta steam'n press DA 75
  • Anonymous Mar 13, 2014
    the iron wont steam and looses water
  • Anonymous Mar 17, 2014
    No idea y hot water and steam the water is leaking out of the side calc looks very scary and unsafe
  • Anonymous Mar 19, 2014
    can't remember how to fill the tank
  • Anonymous Mar 21, 2014
    cord reel does not work -- how to fix the reel
    to retract cord
    my cord retract does not work anymore, This is my 3rd rowenta iron, I don't have a problem with leakage or with the auto cut-off just a bad cord reel
    my cord will not retract. there is absolutely no leakage. i don't have a problem with the auto cut-off feature. I cannot retract my cord
  • Anonymous Mar 25, 2014
    My Rowenta steam iron is almost three years old. As of recently the switch is not turning on the iron, after several tries I would get a flicker. Can the switch be replaced?
  • Anonymous Mar 26, 2014
    I did not use distilled water.Will it work if I empty the tank and refill it with distilled water?
    The white sliding button on the nose of the iron which controls the amount of steam, fell out. How can I get it back in?
  • Anonymous Mar 30, 2014
    The steam is not getting to the iron outlets how do we auto clean the unit?
Using tips from previous commenter, Jason Collins, I thought to check for any blockage in the water flow.
Anyway, if you take out the water "tank" there is a black piece and a white/clear piece that are removable, I removed the white/clear piece and now it works fine! Hope it works for ya'll too.
Posted on Oct 26, 2012
  • 417 Answers
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
It will not steam. We put in a solution of vinegar and 2 parts water from a pitcher that filters water. Will this be considered distilled water or is distilled water critical?
Distilled water and filtered water are not the same. Distilled water is water that has been boiled then condensed so that most of the impurities that cause water hardness (Sodium, Calcium, etc.) have been removed. Filtering does not remove these which is why your iron will clog up much quicker. Same applies to your car battery, distilled water only! To clean it mix "Lime Away" with water about 1/4 cup with water every 6 months or so, then rinse with clean water a few times to get rid of the green color, steam until it comes out clear again..
Mar 10, 2015 | Rowenta IS9100 1550W Precision Valet...
How do I fill my rowenta portable handheld steamer
read your instruc. manual please download from www.retrevo.com
and proceed according.
God bless you
Aug 02, 2012 | Rowenta Steam 'n Press DA75 Iron
Water keeps coming out after pressing steam button
hi i have just looked this information up and apparently that using 100% distilled water can cause your iron to spit and leak, to solve this problem you should press the steam button and keep pressing it until there is no water left in the iron, then try it again, if it still does this, repeat a few times and then the iron should be fine
hope this helps
Feb 28, 2011 | Rowenta DG5030 Iron
How to put water in it
Hold the steam button down and slide the part with the water reservoir down; it will release.
Dec 04, 2010 | Rowenta Steam 'n Press DA75 Iron
How can I demineralize my rowenta iron? I use carbon filtered water in it. The last time I used it white stuff came out of the steam ports and it sounded like there was sediment inside when I moved the...
Fill the resevoir with a 25% vinegar to water solution & turn on the iron until it steams. Allow to cool and empty resevoir then rinse with clean water. Fill up resevoir and & turn on the iron until it steams again. Cool, empty & rinse again. DONE!
Only use distilled or reverse osmosis water in your iron. This will reduce mineral build up.
Nov 13, 2010 | Rowenta Irons
I love my iron, BUT I used to be able to clean it by the recommended method, but now it will not shoot out steam to clean the holes. It does not steam on clothes even though I prees the steam button. ...
Put in as much white vinegar as possible and then turn iron on. Let it stay on for about 30 minutes the try the steam button. Once the steam button begins to work empty the vingar an fill with distilled water to rinse. You'll need to rinse several times to get all of the vinegar out.
Sep 28, 2010 | Rowenta Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
When using the steam it spits out sediment on the clothes. I have tried cleaning by holding the steam button.
This happens due to limescale and / or build ups of mineral deposits such as iron in the water. You will need to use a kettle descaling solution or an iron descaling solution available from most supermarkets or home appliiance stores and clean out the debris in the iron. It happens to most if not all irons and cleaning on a regular basis is the only answer or use very expensive 'iron water'
Sep 28, 2009 | Rowenta Powerglide DE011 Iron with Auto...
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Rowenta steam generator
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta Steam 'n Press DA75 Iron Logo
1,540 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
