1. Turn the printer on. 2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid. 3. Release the green SELECT button. 4. The control panel will display SELECT LANGUAGE. 5. Press the DOWN ARROW button until control panel displays COLD RESET. 6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence. Hopefully, this will fix the problem for you!
If the toner LED still lit even after replacing the drum unit then you know that the Drum counter may not be reset. you need to reset the drum you can rReset the Drum counter as follows:
Open the front cover.
Locate the control panel button under the LED lights on the left side. Press the control panel button until all lights are lit, then release it. The Drum counter is now reset.hope this helps
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
This worked great - press Sani Dry, then press Heated Dry - then repeat - press Sani Dry, then press Heated Dry. All control lights will light and then press Cancel. The control panel should work normally.
press heated Dry , Nornal, Heated dry Normal: The machine will go into diagnostic mode. this may reset your control.
If not clear the fault, unplug the power cord,open up the electronic control panel again and check your connection, maybe the wire harness to the drain relay pin is not connected correctly.
