Question about JVC AV-27230 27" TV
White lines at top of av27230
Has white horizonal lines at top about 2in when first turned on then goes away after about 2-3min and one white line stays about 2in from top
  • 1 more comment
  • ddon Feb 28, 2008
    Replaced c424 that repaired TV thank for all your help.
  • Anonymous Feb 29, 2008
    don't know much about tv. did replace C424 and fixed the same white lines. other symptom; top of picture rolled over
  • ddon Feb 29, 2008
    your solution was the right one thought i gave you the top rating meant to sorry
    Brigadier General:
  • 6,966 Answers
Your posted description is a known (common) problem for the JAV-27230 and should be easily repaired. The vertical capacitor (C424 - 100uf/35V) needs to be replaced. It is relatively cheap and can be bought from any electronics parts store.
in some instances, it could be the vertical IC starting to fail or even a simple case of cold solder.
As always, extreme care when repairing the insides of a TV unit since HV can still be present even when off and unplug. A little knowledge of electronic components and use of a soldering iron should do just fine. Should you not be comfortable doing a DIY, then perhaps you can ask the assistance of a buddy who has some soldering experience.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Posted on Feb 10, 2008
  • Louie  Role
    Louie Role Feb 29, 2008
    Hi again,
    Am glad that your TV has been repaired.
    Would appreciate if you can reconsider the "rating" of my solution as you see it fit. Would be much obliged.
    Cheers.
  • Louie  Role
    Louie Role Mar 01, 2008
    Glad to be of assistance and appreciate the new rating too.
TV has a thin white line in center of screen.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jul 02, 2017 | Panasonic CT-25G6 25" TV
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
I have a 50 in samsung plasma tv and it sudenly had a 2in wide black and colourrd line from top to bottom appear ? any idears
try and bend the set slightly. IF line goes away suspect ribbon cable connector from x driver boards to panel. The connectors brake away from panel and thus a replacement panel must be installed.
Feb 18, 2011 | Samsung 50 in. Plasma TV
Denon reciver and white lines accross the top
try cable box Direct Connect to tv...if all ok ..need replaced receiver if sam problem replaced cablen box...
Apr 09, 2010 | Audio Players & Recorders
When I first turn on my TV, I get horizonal faded lines
it probably has leaky capacitors in the hyper board or the video process board, this repair requires a qualified tv repairman, you can't do it yourself, alot of actual repairman can't handle this repair. it will get progressively worse as time goes on the more leaky the capacitors become.
Sep 07, 2009 | Toshiba 42H81 42" Rear Projection...
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
Lines
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to fix the problem.
Dec 24, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
No one has been able to give me an answer
Sounds like insufficient vertical sweep and the top lines are getting out of control.
Check all the electrolytic caps in the vertical circuit for testing dry (sorry - takes a special meter to do it in circuit) or just replace them. Look the I.C. up in the free NTE crossreference at nteinc.com get a diagram of its pinout to find what pins the power and outputs are on.
Hope ya fix it!
Aug 28, 2008 | Mitsubishi WD-62827 62" Television
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
JVC AV-27230 27" TV Logo
74 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
