Question about Nikon Coolpix S51c Digital Camera
On/Off Switch issue
Is there a lock feature on the on/off switch because the camera turns on randomly when I put it into the bag. I have to remove the battery each time I am finished taking pictures so the camera won't fire while stored. What a pain!
  • 104 Answers
This is simpleproblum ur on off microswich is badly pressed replace ur swich
Posted on Mar 04, 2008
How to remove the steering wheel for replacement
SIR DISABLE:
DRIVER SIDE
Many service procedures require the air bag system to be disabled to prevent accidental deployment. The air bag system can maintain sufficient voltage to cause deployment for up to 2 minutes after the ignition switch is turned off, the battery ground cable is disconnected or the DERM fuse is removed. If the inflator module is disconnected from the deployment loop by the following procedure, service can begin immediately without waiting for the 2 minute time period to elapse.
  1. Turn steering wheel so that vehicle wheels are pointed straight ahead.
  2. Turn ignition switch to Lock position and remove key.
  3. Remove air bag fuse from fuse block.
  4. Remove steering column filler panel.
  5. Remove Connector Position Assurance (CPA) and disconnect yellow two-way connector at base of steering column, Fig. 1.
PASSENGER SIDE
  1. Remove air bag fuse from fuse block.
SIR ENABLE:
Driver Side
  1. Turn ignition switch to LOCK and remove key.
  2. Connect yellow two-way connector and install connector position assurance (CPA).
  3. Install steering column filler panel.
  4. Insert air bag fuse into fuse block.
  5. Turn ignition switch to RUN and verify that the air bag warning lamp flashes seven times then turns off.
Passenger Side
  2. Insert air bag fuse into fuse block.
  3. Turn ignition switch to RUN and verify that the air bag warning lamp flashes seven times then turns off.
Apr 10, 2015 | 1996 Chevrolet K1500
Ignition switch need removing
if this is your first car? do wiggle the steering to unlock the dogs
and 100x that if parked down or up hill , wheels to curb. RTM
read the operators guide , its covered.
lost the guide? in the glove box have you? bingo.
http://justgivemethedamnmanual.com/honda/
read the pages on key , and locks.
are you asking how to REMOVE IT? the Verb missing,???
this is covered in the FSM. buy one, lots of steps it is...
alldata.com covers this.... read it, and defeat the AIR BAGS first. !!!!
here are some free FSM , honda;s are great that way.
http://hondatech.info/downloads/Auto/Manuals/Accord/
on most cars. , "GENERIC RESPONSE"
battery neg lug, removed and safed off (warp in towel> so it cant land on post accidentally) .
I recommend, always to READ THE MANUAL. the FSM.
the factory service manual.. (it's for real mech, not DIY but is best)
RTM, read the FSM on air bag defeats, some can retain a charge for hours. or more... RTM it's your neck not getting snapped.
1; BATTERY PULL NEG LUG.
2: DEFEAT AIR BAGS.
3:remove steering wheel, (rtm) (a whole section just that)
4: do not damage the Air bag coil spring(above) or be real angry when it fails
and not pass smog test , gigs yah.......oops. or cant sell car?/ oops......
5: remove the plastics, there. (wrap) (bottom screws)
6: remove column , switch clamp , most cars show a set of anti-tamper screws here, (RTM) we must destroy them to take them off , and replace them later.
7: cables removed from switch.
8: the whole switch assembly is free, key on. (not locked)
9: out it comes. off end of column.
the key switch is protected with antitamper features.
read about them, then attach the switch.
Dec 26, 2013 | 1996 Honda Accord
I NEED HELP REPLACING THE IGNITION KEY SWITCH ON A 1998 HONDA PASPORT ?
To remove the ignition lock:
CAUTION
You must remove the steering wheel when replacing the ignition lock. On vehicles with a Supplemental Inflatable Restraint (SIR) system, you must temporarily disable the SIR system and remove the inflator module when removing the steering wheel. Leaving the SIR system on could result in deployment of the air bag and possible personal injury.
  • Disconnect the negative battery cable, and remove the steering wheel.
  • Remove the bumper and the carrier snapring retainer from the steering shaft.
  • Use a lock plate compressor screw tool to install the lock plate compressor screw in the upper steering shaft. To keep the shaft from telescoping, tighten it to 40 inch lbs.
  • Using the lock plate compressor tool, install on the upper steering shaft, tighten it to depress the shaft lock. Remove the shaft lock retainer, the compressor tool and the steering shaft lock.
  • Remove the turn signal canceling cam assembly. Put the turn signal switch in the "N" position and remove the upper bearing spring.
  • Position the turn signal switch so the mounting screws can be removed through the holes in the switch and remove the turn signal lever.
  • Remove the turn signal switch-to-steering column screws and lift the turn signal switch. Remove the wire protector and disconnect the turn signal switch connector.
  • Use a terminal remover tool to disconnect the buzzer switch wires from the turn signal switch connector. Remove the buzzer switch assembly with needle-nose pliers.
  • Place the lock cylinder in the ACC position, then remove the lock retaining screw and the lock cylinder set.
  • To install the new cylinder lock, reverse the removal procedures.
  • Tighten the lock retaining screw to 22 inch lbs., the turn signal switch screws to 59 inch lbs. and turn the turn signal lever screw to 53 inch lbs.
  • As part of the final replacement procedures, check the operation of the switches and the steering column.
f42-11.gif The steering wheel is splined to the steering column and held in place by a nut. Courtesy of General Motors Corporation - Service Operations.
Nov 30, 2012 | Toro Genuine Ignition Switch P 27-2360 "...
My camcorder won't record. The memory card icon on the screen shows a lock on it as though it's protected so the camera won't record while in a bag etc. How do I turn that feature off so that I can...
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 13, 2011 | Aiptek IS-DV2.4 Camcorder
My 1995 f-150 ford needs a new key ingintion lock, i can start the truck without the key. is this a easy fix?
CAUTION
Aug 10, 2010 | 1995 Ford F150 Styleside Regular Cab
How to Remove an Ignition Cylinder From a Toyota Camry 1994
prev.gif next.gif Ignition Lock/Switch REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable. If equipped with an air bag, wait at least 90 seconds before working on the vehicle. CAUTION
    Some models covered by this manual may be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Section 6.
  2. Remove the lower steering column cover. Unfasten the ignition switch connector under the instrument panel.
  3. Remove the screws which secure the upper and lower halves of the steering column cover.
  4. Turn the lock cylinder to the ACC position with the ignition key.
  5. Push the lock cylinder stop in with a small, round object (cotter pin, punch, etc.). NOTE: On some vehicles, it may be necessary to remove the steering wheel and combination switch first.
  6. Withdraw the lock cylinder from the lock housing while depressing the stop tab.
  7. To remove the ignition switch, unfasten its securing screws and withdraw the switch from the lock housing. To install:
  8. Align the locking cam with the hole in the ignition switch and insert the switch into the lock housing.
  9. Secure the switch with its screw(s).
  10. Make sure both the lock cylinder and column lock are in the ACC position. Slide the cylinder into the lock housing until the stop tab engages the hole in the lock.
  11. Install the steering column covers and connect the ignition switch wiring.
  12. Connect the negative battery cable.
Jul 17, 2010 | 1994 Toyota Camry
Turn signal on 97 Lumina not working
Yep ,sounds lke the switch.and yes on the air bag,no big deal.pull the air bag fuse (or better still the battery) wait 15 min then pull the bag . Just unbolts like a horn button.Pull it out and unhook the yellow lead to the clock spring. GM uses a retention clip on the airbag connector,just slide the little clip out then the connector is normal.Place the bag soft side down while it's out.Have to be sure not to turn the wheel once you start the project.
There is a clock like spring that is for the air bag. If it turns too far the spring will break and the bag will not work.As you remove the yellow clock spring it will lock itself,don't push on the lock button,it will spin around inside and break.
A few special tools involved for a clip on the steering shaft and pulling the wheel ,bet the parts store will rent 'em tho
Aug 21, 2009 | 1997 Chevrolet Lumina
How to remove an ignition switch on an 1991 caprice
See Figure 1
0900c15280047a11.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Ignition switch assembly
If equipped with an air bag system, make certain to follow the recommended disarming procedure before, and rearming procedure after, repairs.
  1. Disconnect the negative battery cable and disable the air bag system, if equipped.
  2. Remove the column to instrument panel trim plates and attaching nuts.
  3. Lower the steering column and disconnect the shift indicator cable.
  4. Disconnect the ignition and dimmer switch wire connectors.
The steering column must be supported at all times to prevent damage.
  1. Remove the switch attaching screws and remove the dimmer switch followed by the ignition switch.
To install:
  1. Move the key lock to the LOCK position.
  2. Move the actuator rod hole in the switch to the LOCK position.
  3. Install the switch with the rod in the hole. Adjust the ignition switch as follows:
    1. 1990 - Place a 3/32 inch drill bit in the hole on the switch to lock the switch into position. Move the switch slider to the extreme left position then move the slider 1 detent to the right OFF LOCK position. Remove the drill bit.
    2. 1991-93 - Install the ignition switch in the LOCK position. Move the switch slider to the extreme right position and move the slider 1 detent to the left LOCK position. Depress switch mechanism slightly to insert a 3/32 inch drill bit into ignition switch.
  4. Position and reassemble the steering column in reverse of the disassembly following the proper coil centering procedure. Enable the air bag system, if equipped, as follows:
    1. Connect the yellow 2-way SIR harness connector located at the base of the steering column.
    2. Install the SIR fuse to the fuse block.
    3. Turn the ignition switch to RUN and verify the inflatable restraint indicator flashes 7-9 times and then turns off.
Jul 29, 2009 | 1991 Chevrolet Caprice
I need to take out old ignition lock cylinder without key on 1989 toyota camry le -lost keys-bought locksmart replacement but it says old has to be in acc position to remove-
This is what the tech manual says.....
Jul 26, 2009 | 1991 Lincoln Town Car
1992 cavalier ignition switch and key assembly
The following procedure is "generic" for replacing the lock cylinder. There are a couple of specialized tools you will need and saftey precautions concerning the air bag system.
Take a look and let me know if you wish to tackle the job.
Regards,
CAUTION You must remove the steering wheel when replacing the ignition lock. On vehicles with a Supplemental Inflatable Restraint (SIR) system, you must temporarily disable the SIR system and remove the inflator module when removing the steering wheel. Leaving the SIR system on could result in deployment of the air bag and possible personal injury.
Mar 04, 2009 | 1992 Chevrolet Cavalier
Nikon Coolpix S51c Digital Camera Logo
35 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
