Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Inside view Hi I need an exploded view of the inside of a Bissell 7901w proheat carpet cleaner. Broken Pieces fell out. What connects from the inside of the floor to tool switch and to where? Thanks Gary
Found what I( am looking for. Thank you
Posted on Feb 11, 2008
    President:
  • 1,673 Answers
Maybe this pic. will help:
I need a diagram of the hose connection in a Bissell Proheat model 1699-r
Bissell Proheat Carpet Cleaner Parts & Repair Diagrams
www.vacpartswarehouse.com > BISSELL
The Bissell Proheat Series Vacuum Parts, Repair Schematics, & Accessories. ...Bissell Proheat Proheat Cleaner 25A3 ... Bissell Proheat Deep Cleaner 1699 ..
Aug 30, 2015 | Bissell Vacuums
Will not **** the water off the carpet.
If the carpet cleaner won't "Extract" water from the carpet, try using the upholstery / hand tool. If you have suction there, your selector switch / knob is either in wrong position, or broken. There may also be a tear in the hose on the inside of the cleaner, or the waste tank is not sealing well.
Jun 13, 2010 | Bissell 1699 ProHeat Clear View Upright...
How to use the bissell proheat Carpet cleaner 8910
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Jan 18, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How do i disassemble bissell proheat model 8910 carpet cleaner to check motor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Nov 06, 2009 | Bissell 8910 ProHeat Clear View Upright...
I have a bissell steam cleaner. the hand piece
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
a
Sep 26, 2009 | Bissell 1699 ProHeat Clear View Upright...
The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
Jun 08, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell proheat 2x carpet cleaner
heatman101
May 30, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 7901w
You need to order a hood assemble. it comes with the switch. make sure you are careful putting the hood back on. in some cases you may need to get the whole housing. there are 6 screws holding it together. before putting the housing back make sure to put a small block of wood under the bottom between the wheel not on the wheels. this will help to lift the bottom so you can screw back the housing.
Feb 09, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
251 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
