CD Player problem
Player takes in disc fails to spin disc therefore wont read disk. problem is intermitant.
  • 1 more comment
  • MadAtOnkyo Jul 04, 2008
    CD stops at some moment for no reason, thereafter CD recognition
    degenerates (apparently TOC gets corrupt), to the point that won't even
    register a perfectly good CD. Symptoms disappeared overnight the first
    time this happened (I unplugged the unit). It has ocurred a second
    time, still wait6ing.
  • ho12vah Aug 10, 2008
    cd player wont read any disk continually getting the no disk error.
    Tryed cleaning the laser with a que tip and alcohol but nothing.
    might be due to overwhelming heat, not too sure?
  • Joe M Nov 16, 2008
    My Denon DCM-370 will only read one of my discs on rare occasions, and never reads any of the others. I'm sure it is not spinning up the disc, because I have listened when it as able to spin up that one disc, and when it tries to spin up others, it clicks 4 times then moves on to the next disc bed.
    Brigadier General:
  • 6,966 Answers
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded;
5. relube, clean as necessary
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 11, 2008
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
The CD player will rotate but won't play as though it's not reading.
How to Fix your CD Player ' Librarian in Black Blog - Sarah ...
librarianinblack.net/librarianinblack/how_to_fix_your/
Well, if I was a junk pack-rat and still had all the CD players I've thrown away because they stopped ... my portable cd player lens looks to be scarched how can i fix its ... my 3 disk memorex cd player won't play any thing. it was working fine and then allof a sudden it stopped on me it won't even spin the cd to try to read.
No Disc Error, not reading CD error: Repair Sony CFD 112 ...
? 11:35
https://www.youtube.com/watch?v=iEG_u0ogjZI
Jul 23, 2013 - Uploaded by 1000uf
How to troubleshoot and repair CD player not reading disc, table of content (TOC), ... +DeathlyHall0w It's ...
? 5:15
If you move the boombox with the audio CD player will it slip, with this model? ... I cannot buy a new boom box ...
Why won't my disks spin? - GameFAQs
My cd player wont take cd
CD players do a little POST before they show you the disc contents. The disc first spins up then the laser head skips across to read the index with is generally on the inside track near the center. If the CD doesn't spin or the head doesn't move the CD player will auto-eject the CD. I'd have that player serviced or replaced.
Jan 17, 2015 | 2004 Nissan Maxima
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
Dvd player always says no disc . will not load
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Aug 28, 2009 | Philips DVP3962 DVD Player
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
When playing cd player , cd rotates angle of 5 degrees clockwise
Hi there
It is probable that you will have a faulty spindle motor if the disc wont spin up to speed. Have you been able to give the disc a kick start to get it to read. The disk also has to spin the fastest when reading the table of contents after the disc is first loaded. Sometimes when the suspension rubbers to the laser fail, the disc may also be catching on parts of the mechanism preventing it from spinning up to speed. Can you give me a little more about how the problem is occurring, particularly what noises you hear, and whether you can kick start the disc to spin. I have plenty of experience repairing these players, and am happy to answer any questions you may have about it. Cheers
regards
robotek
Dec 11, 2008 | Pioneer Audio Players & Recorders
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
No disc displayed
The disc won't spin until the unit recognizes that there is actually a disc there. Try cleaning the lens using a cotton swab and alcohol. If that fails, try playing a CD. If the CD plays, the optics are starting to fail as reading a DVD requires higher laser power.
Dan
Mar 19, 2008 | Cyberhome DVR 1600 DVD Recorder
486 people viewed this question
 Grubhead
Grubhead
