Question about Lexmark X6170 All-In-One InkJet Printer
Cartridge error message 50C no printing at all what do you suggest
    Sergeant:
  • 390 Answers
Hello, Clean it both manually and with printers own cleaner program then try running an auto alignment page. Good luck lilacgerry xxx
Posted on Feb 10, 2008
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
Not printing. shows error 50C
Cartridge Error 50C
Jun 13, 2009 | Dell A940 All-In-One InkJet Printer
LEXMARK X5150 CARTRIDGE ERROR
Try this --
Cartridge Error 50C
Cartridge Error
Nov 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
DELLA 940 DOES NOT PRINT
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jul 20, 2008 | Dell A940 All-In-One InkJet Printer
Error code 50c
Cartridge Error 50C
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
May 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Cartridge Error
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6100
Cartridge Error 50C
Good luck and dont forget to rate me!!!
Dec 19, 2007 | Lexmark X6100 Flatbed Scanner
Lexmark X6170 All-In-One InkJet Printer Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
