Question about Coby DVD-755 System
Coby dvd 755 home theatre system hook to directv
I have the system hooked up but I have Directv and I am not sure if I hooked up the red/white/yellow sets in the right spot. I put it in the back of the Directv box, but only some of the speakers are working, and I can't figure out which buttons to push to make the theatre systems remoted co ntrol work or to watch the dvd's. They play , but I only see my directv channels.
  • 43 Answers
The composite output (red, white and yellow) on the directv receiver should connect to the audio in (red and white) on the coby ht system. Then you have to select the correct input on the coby til you here the audio from the DTV receiver
Posted on Jul 25, 2009
SOURCE:
Directv can't connect my tv to he, what can I do, they say I need a green plug in in the back,with the red, yellow, white
What I believe they are trying to tell you is you need to hook up into a component input . It is a video input only and it has three jacks usually coloured red green and blue. Match up the colours with the receiver and you will get an HD picture. They way you currently have it hooked up is a composite connection with only the yellow being for picture. This cannot get you an HD picture. The red and white is for the sound. I don't know what you mean by he though.
Sep 24, 2015 | Emerson 42" Plasma Tv Pl-p42w-10a 720...
I just got a new LG 42LK530 TV and cannot figure out how to hook up my Go Video vcr/dvd . I also have Directv HD
You have them hooked up right. Are you beyond that, I mean is it not activating?. If so, be sure you scroll through the video settings. It should then connect.
Dec 07, 2011 | GoVideo Go Video DVD/VCR Combo
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
How do you connect a dvd player to the back of the 42''JVC LCD ?
the directv needs hookedup to the tv, also the dvd player needs hooked up to the back of the tv, what type of cabling are you using, red/white/yellow or coax (where it screws in) or does it plug in and say hdmi, etc.
Apr 04, 2009 | JVC LT-42X688 42 in. LCD HDTV
Help hooking a dvd player to a tv
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
Mar 24, 2009 | Panasonic DMR-E30 DVD Recorder
How to i hook-up a directv dvr plus to two tv's?
plug one tv using coax (screw in cable). plug the other using composite video cables( yellow, red, white). It will be easy to connect the tv that's the farthest with coax, its cheaper to purchase 50ft of coax vs 50ft of composite video.
Jan 03, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Unlock the coby DVD-755 to free region use
I believe this works - I've yet to try it myself! Coby DVD-755 1 user region code/hacks August 13, 2007 Post region code/hack comment Region code hack posted by Peter, August 13 2007: DVD -755 from Walmart home theatre for $79.00 1-Press ?Setup? 2-Press Vol +, Vol-, Vol +, Vol -, 3-Number shows up 4-Change the region code by using RIGHT arrow. 5=Press ?Setup? to exit. Succesfuly tested bt Peter F.
Jun 29, 2008 | Coby DVD-755 System
Home Theatre System
well u can run direct tv to tv then the tvs master digital out to the rca digital in or anlog rca cable
Jan 27, 2008 | Audio Players & Recorders
Surround sound
Make sure the RCA cable is going from an audio OUT on TV or DirecTV box to a red/white (non-digital) audio IN on surround sound or home theater system.
Dec 29, 2007 | Insignia NS- 27" TV27 TV
Coby DVD-755 System Logo
268 people viewed this question
Top Coby Audio Players & Recorders Experts
Ekse
Joe Negus
Joe Negus
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
