Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the
picture to look normal. This is called convergence.
When its out of alignment the video will look
3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the
time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection
TV sets including
Sony,
Samsung,
JVC,Philip
Magnavox,
Panasonic,
Akai,
Pioneer,
Hitachi,
Mitsubishi,
Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from
TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks
3-D *Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video -
TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking
picture *White looking
picture *Halos around objects
*Red/Orange looking
pictureSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I got both stk392-040 installed and no luck....same thing with the out of convergence problem.....I also noticed that when i try to do the perfect focus feature i get no sensor data....Any other solutions?
I found 2 pico fuses in between the fins of the heatsinks 1 at each heat sink. No continuity at one fuse and will take it out circuit to be definitely sure. I'll let you what get when i replace it.
still no sensor data but pico fuse was definitely blown..replaced it and now ok . Any suggestions on the no sensor data for perfect focus option?
Thanks for your extensive help in repairing my Samsung HCL473W
projection TV. Your help saved me hundreds of dollars in repair costs that would have had to be paid if I went to a outside source.
Again...Your help was much appreciated....Thanks C-Dog for replying to my post.
please please please help me, my perfect focus is out, and I wondering if I just need to get a new tube for my samsung HCL473W. The blue is out of whack, and I cant get it to line up behind the yellow squares. Please help
