Question about Canon P23-DH Calculator
Staples SPL-P100 calculator feed
Argh! I have read past posts on other calculators and see the slot in the back, try to feed the paper in, stick it in between the fine silver slot and pressing the advance button, #sign (there is no *star* sign). The machine chugs along, but will NOT grab the paper, which I have cut very carefully into a point, very straight, and even on a slant. Blah!
  • 3 more comments
  • Anonymous Feb 29, 2008
    The design is incredibly stupid and is impossible to feed the paper! Why would anyone design a paper feed like this??
  • mikado Mar 05, 2008
    Oh thank you! It took a bit of fiddling, pushing the bubble of Post-it note down as it resisted going through, but it worked.
    I gather the paper on the rolls Staples sells for this calculator is not thick enough. The somewhat thicker Post-it does the trick and has the sticky on in to pull the roll through. Thanks again. Very clever.
    (A pink Post-it works too ;-))
  • Anonymous Oct 04, 2008
    I've tried the post it, it doesn't want to feed at all!
  • mikimaru Nov 15, 2008
    please show or write and let me know how to feed the paper into a cannon p100-dh calculator i am having problems with is i try to feed the paper through the silver and the black part and it wont work HELP!
  • Anonymous Dec 04, 2008
    How do you feed the paper what slot. Behind the black slot or what
Okay. Tried the other ways listed here, did not work.. BUT fold the paper into a point.. then feed through.. it worked the first time!!
Posted on Jun 21, 2012
  • 168 Answers
There could be something stuck inside the unit. Try taking a business card and pushing it into the silver slot at the same time pushing the advance button.
Worst case senerio, bring it back to Staples and ask someone there, IM sure that someone there can get the paper to feed in seconds if there is nothing else wrong with it.
Sorry I couldnt be more help.
Good luck.
Mac
Posted on Feb 10, 2008
I've been trying for several occassions but in the end, the sticky worked very well for me too!!!! Tip: Just cut a little piece of the sticky note and make sure to stick the edges to the roll together and push while pressing the feed button....
Posted on Dec 07, 2010
  • parisme Dec 07, 2010
    The sticky worked pretty well. Tip: Just be patient and make sure to stick the edges together and push slightly...
I used a yellow post it note to catch the feeder on the machine, it fit perfectly and caught right away, then I just put it on the paper I was trying to feed in. Worked very well for me.
Posted on Mar 05, 2008
  • prs102 Oct 10, 2010
    take the paper and fold it to make a point in the middle of tape roll( like making a paper airplane) push it though till it catches the roller in the middle-keep hitting feed button till paper is long enough to grab--worked for me
How do I get 2 decimal points in a Staples calculator SPL P100
There is a tab button that controls the number of decimal places you would like. press tab and it will change to 0-2-3-4-A-F showing on the bottom of the screen.
Hope this helps!
Feb 09, 2018 | Staples Office Equipment & Supplies
How to stop it from rounding up or down
Did you try it on the "F" position?
Good luck,
Paul
Oct 03, 2016 | Staples SPL-P100 Printing Calculator
How do I feed new paper into calculator?
I don't know if it helps but small printers such as these often need a "point" or diagonal fold/cut to be presented to the input slot.
Jul 15, 2016 | Staples SPL-P100 Printing Calculator
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
How to install paper
Without a manual, look at the picture of the calculator. Mount the paper, with the feed coming forward and over the top of the calculator. Insert the paper (recommend cutting it flush) into the feed slot in the back. Then use the paper advance key to advance the paper through the rollers. Unfortunately the manual is not available from the Staples website. Good Luck,
Mar 02, 2015 | Staples SPL-P100 Printing Calculator
How do I load the paper in my SPL-P500 calculator?
Try making a point and feed it in the right place, the feed roller which is only about 1/2 inch wide should pick up the paper.
Feb 13, 2015 | Staples SPL-P500 Printing Calculator
How to feed the paper into the SPL-500 and how to set for printing?
You feed it from the back,(you will see an horizontal line) you're paper has to be straight cut, than you press the arrow on the left corner until you see it on the front.
Apr 20, 2012 | Staples SPLP500 Scientific Calculator
Change decimal placement on calculator
pressing the tab button displays the number of decimal places 0, 2, 3, 4, A, F on the bottom of the screen.
Jun 22, 2010 | Office Equipment & Supplies
How do I install adding machine paper roll
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Nov 23, 2009 | Canon P1-DHV Calculator
Canon P23-DH Calculator Logo
6,545 people viewed this question
old marine
old marine
