Question about Maytag Neptune MAH5500B Front Load Washer
Won't wash When you turn the washer on for a load, it begins, locks the door, and then stops. Then, none of the buttons can do anything to start it up again. So, to sum up, it starts for a few seconds, then stops working, but the door is still locked.
  • 1 more comment
  • Anonymous Feb 24, 2008
    placed a load in the washer it locked then it buzzed 3-4 times then the letters "do" was displayed on the screen. Was able to override the lock on the door but it continues to do the same thing over and over.
  • Gary Davd
    Gary Davd May 11, 2010
    has the motor controller board ever been replaced
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    hmmm...sounds like a timing circuit issue. new/old/ what?
  • 156 Answers
Also the wax motor and microswitch in the door lock can do it
Posted on Feb 25, 2008
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
The door is locked on my front loader washer.
PUSH THE START PAUSE BUTTON, AND CLEAN THE LINT TRAP AT THE BOTTOM OF THE UNIT
ROB
Apr 14, 2009 | GE WPXH214A Front Load Washer
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer stops and starts and door lock light remains on
You probably have a bad door latch or door interlock. Both, if defective will cause the symptoms you describe. The door must remain closed and lock before a wash cycle will begin, and for it to complete properly.
Jul 10, 2007 | Frigidaire FWTBB30DS Front Load Washer
Problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Oct 23, 2006 | Zanussi FLE1416W Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
