Question about Mitsubishi WD-52725 52". Rear Projection HDTV
How can I clean the mirrors on this tv?
The picture is not what it was. I was told the mirrors need cleaning. What is the correct way to do this and can I do it myself?
  • clete Feb 10, 2008
    really appreciate the information. Find it hard to believe that a dry cloth will clean mirrors. Is this a special cloth?
    Probably need a manual showing the inner mirrors, do you know where I can purchase this. Thanks again, Clete
    Sergeant:
  • 395 Answers
To clean the mirrors you must remove the screen first there are several screws in the back to remove the screen. then there is a mirror shaped like a polligon clean this with a dry cloth do not use a paper towel. soft colth must be used on any optical surface. then clean the optical engine lens in the same manner. them the large mirror in the back. remeber if you leave a defect on any of these surfaces it will be amplified by the screen. this system relies on a lamp to provide bright picture so replace that as well. this should be a part of your anual cleaning agreement of the after market warranty you purchased assuming you bought one. dim picture = lamp, fuzzy, dim, dull picture = dust
Posted on Feb 10, 2008
  • Robert Johnson Feb 10, 2008
    all you are doing with the cloth is to remove dust. a damp cloth will leave streaks the will show up in the screen. the cloth can be a lint free soft cotton cloth (this is what my company uses) or a soft shammi. if you are thinking of the DLP mirrors, that is an IC chip 1" x 1.25" sealed system made by TI. these mirrors (micro) can never be cleaned nor could they ever get dirty and is part of the light engine.
2 Suggested Answers
  • 133 Answers
SOURCE: Can I clean projection tubes myself?
First unplug set and remove back cover then you should see the three picture tubes . Using a soft cloth spray windex on the cloth then clean your lens and use the dry side to wipe away . Do not press hard as the lens are plastic . If you cannot see the tubes thru the back side you must enter thru the front . Would need to know make and model # of your set located on the if you need more assistance . If you are a smoker this could very well improve your picture . Good luck
Posted on Mar 01, 2008
What can I use to clean the mirror on my 65" MItsubishi model #65737??
If its a WD 65737 do not attempt it---special mirror and any marks will show in picture---Contact Mitsubishi as they do make a special liquid cleaner for this but real care has to be taken, not to mention just getting at the mirror correctly-----why does it need cleaning?
Dec 03, 2012 | Mitsubishi Televison & Video
My Sony KP53S35 rear projection TV has a very dim picture and I was told that I need to clean the mirrors. Can you tell me how to take apart the TV to get to the mirrors and how to clean them?
chance are your problem is the projector lamp and not the mirrors. if the tv is 4 years old or more buy a new lamp, they are easy to change. as far as the mirrors go, you have take the back off to get at the mirror but its a lot of work try the lamp first.
Mar 12, 2011 | Televison & Video
Dull picture on my KP61s65
You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Nov 27, 2008 | Sony KP-61S65 61" Rear Projection...
Smoked out
UNSCREW THE TOP BLACK PLASTIC, IT HOLDS THE MIRROR SO BE CAEFULL WHEN YOU REMOVE IT, FROM THERE IT WILL BE OBVIOUS WHAT TO DO, CLEAN THE MIRROR, BULBS AND BACK OF THE SCREEN. GOOD LUCK
Nov 05, 2008 | Hitachi 53UDX10B 53" Rear Projection...
D40x Camera with mirror lens = black pictures
Usually tele lenses need longer exposure,and mirror lenses need more than normal lenses.Try with 1sec, half sec,( 2 in the speed dial, not 2" ) or quarter sec (4 in the speed dial) exposures.
One more thing, you need good sturdy stands to hold cameras.
Apr 02, 2008 | Nikon D40x Digital Camera
Mar 01, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Dull picture
Yes you can take the back bottom of the tv off.You will see 3 bulbs 5or6" in diameter.take a very soft clean cloth spray cloth not bulbs.windex persoal cleaner for your glasses ect.wipe bulbs gently removing dust.Above thes lights are the mirror maybe 10"by12" clean that to spray cloth not mirror than wipe clean"Now get limber and try to reach the inside of the big screen and wipe completely.
Dec 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television, dirty innerscreen
The important thing here is cleaning the refelective mirror inside you tv .We have noticed in dirty areas the dirt on mirror makes blurry picture.THerefore you have to open back cover and than tp cover to clean mirror and also dont forget to claen c.r.t lenses ,sisnce they are mounted facing upward ,lot of dust sit on c.r.t lens there fore clean 3 of them r.g.b..And you will notice on picture diffrence.
Dec 18, 2007 | Sony KP-61HS10 61" Rear Projection...
Picture not clear
When you say the picture is not clear please describe what you mean a little more clearly/ Thanks.
Mar 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Maintanence question obout my Sony rear projection.
i,m not a tech but i,ve been told by a techinican that those tubes do have fluid and it,s not an easy fix to change the fluid i was told the tube has to be removed and a tech told me it would run around 200.00 by the time the tech removes it puts the fluid back in and reinstalls it and after it,s reinstalled the convergance has to be reset that,s what realigns the colors back to their correct position and i,ve heard this isn,t an easy job so i,d probably get a techinican to fix it but that,s up to you someone might have an easier opinion but the tech i talked to is one of the best thanks and maybe you can help me i have a blue tube on my big screen tv that wont light upcould you give me some insite as to what you know about a projection light that you said that may need changed think that may be my problem your welcomed to call me about this at 270-566-4327 anytime soon as possible thanks
Nov 26, 2006 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
1,606 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
