Question about NexxTech World Map LCD Clock (6311491)
I just bought the last copy - a floor model with no maual as to how to set the times etc. They said you would provide one online as a pdf. Where might i locate such an item? Thank you. - Carolyn
  • illcome Feb 04, 2009
    I just bought the last copy - a floor model with no maual as to how toset the times etc. They said you would provide one online as a pdf.Where might i locate such an item? Thank you. - Chris please e-mail me @ luke10382004@hotmail.com with the anwser thanks
  • Anonymous Mar 01, 2009
    exactly the same problem. I tried depressing 2 buttons to allow the time etc.to be adjusted - unsuccessful. Manual not available for download either!
2 Suggested Answers
SOURCE: Radio controlled clock model 6302000 - cannot
I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution:
1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds.
2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes.
3. Press the Mode button once to enter programming mode.
4. Press the Adjust button as many times as needed to toggle through the time zones.
5. Press the Mode button once to exit programming mode.
Posted on Oct 08, 2010
I try to set my nexxtech watch . I can't find the way to set the clock ... could you advice me how ?
Without knowing which model you have, this should help.
Go to the following link and near the bottom of the page, choose Category - Watches, Brand - Nexxtech and then choose the Model watch that you have. It will give you the option to download/view the manual to set the time.
http://www.thesource.ca/estore/exclusive.aspx?language=en-CA&category=Watches&brand=NEXXTECH
Mar 14, 2011 | Watches
How do you set the time on the nexxtech am/fm alarm clock with cd player model no.1219568?
Hold the Timer button then press the Hour / Minute buttons to set the time.
Dec 30, 2010 | NexxTech Vacuums
Apr 02, 2010 | NexxTech Travel Alarm Clock (63-8042)
Activate the 24 hr clock function
Press the mode button until you find the setting for 24 hour or 12 hour setting. (It is likely that the message will be abbreviated because of the limitations of the display, so some interpretation may be needed.).
You change the setting by pressing one of the other buttons on your watch - some experimenting may be needed.
Mar 10, 2010 | Watches
How to change settings of Seiko world time alarm & desk clock
I have the user manual for this clock for anyone who sends me his e-mail address.....
indysandy@indy.rr.com
Feb 03, 2010 | Watches
Can't adjust month/date etc....
1)Press "SET" button for more than 3 seconds until digits of certain area blinks.
2)Press " ADJUST " button to increase digit reading value of year, month, hour, minutes...etc. of the blinking area ( Note: all adjustments are towards increasing increments only. Just cycle if accidentally past the required setting )
3)Press "SET" button once to jump from one area of adjustment to the next...example from calendar to month to hour to minutes to seconds....etc.
4)Press "mode" button to confirm all settings
5)Finished
Mar 10, 2009 | NexxTech Transparent LCD World Time Clock...
Lost manual for Nexxtech motion clock. Need to reset
You did not supply a model number and the Nexxtech web site has no information, however, I did track down the supplier, Orbyx
Just enter the info model number etc. and see what comes up.
This is the maker of the Clock.
http://orbyxelectronics.com./manuals.asp?choice1=3&choice2=4&hidPickIndex=2
Dec 18, 2008 | Emerson CKW2000 Clock Radio
Unable to set the time correctly
Try to set it again:
1/Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2/Move the field highlight to the OFFSET field
and press Enter
3/With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4/Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
5. Press QUIT , to return to the MENU Page, then select
Navigation Setup “NAV SETUP” with the Up & Down arrows (↑↓)
then press ENTER
Hope that helps.......
Jul 02, 2008 | GPS
Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
try looking up the manual on the model number you might find it online. I have the maual for this model.
Jun 10, 2008 | Audio Players & Recorders
NexxTech World Map LCD Clock (6311491) Logo
128 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
